2000 Chevy Tracker 4x4- has Suzuki Vitara "facelift" (different grill & headlights). 4x4, 2.0 4 cylinder with 5 speed transmission. (VERY hard to find in a 4 door) 190k highway miles (w/less then 100k on newer 5 speed tranny) Burgundy w/grey cloth interior. Nice condition in/out. It had some of the common lower rocker panel rust that we cut out & repaired & then bedlined them below the doors. "JEFF'S" 1 1/2" coil spacer lift with new Monroe struts & shocks with 30" BFG KM2's. New CV shafts, new clutch, water pump, belts, timing chain & gears, front rotors & pads, custom 2 1/4" exhaust with upgraded factory header style manifold (replaced cracked cast iron manifold), full synthetic oil run in enging & tranny. K&N air filter, Remote Starter (yes, works on a 5 speed), Alpine stereo w/single 10" sub & amp, aftermarket trailer hitch, dark tint on back windows. Nice little 4 door SUV w/4 cyl. & stick w/4x4 & still get 20 MPG in the city no matter how you drive it. Can get 25+ on Highway if driven right. Only Bad is the check engine light is on ever since the removal of catalytic converter/exhaust upgrade. (It triggers rear O2 sensor since cat. is deleted) It doesn't cause any running issues & actually improved mileage. It never bothered me because it still ran great. Only reason I am selling is because we need something bigger (i.e. 96 or newer 2 wheel drive Suburban-possible trade?) to haul around kids & new St. Bernard!
$3500 / BEST Email or call 810-869-9903. Located in Flint, Mi.
