got troubles
  • 14 Replies
  • 2660 Views
got troubles
« on: July 10, 2011, 06:28:46 PM »
i just bought a 88 sammy and wont run with out some fuel in carb. the fuel pump is pumping i can see it so next questin is im thinking float so any info on how to change it? tthe po said it has sat for a few years. so my main ? is how do i replace the float ive had to deal with efi all my life and a little carb but not much lol so as 4 a carb im a noob well someone clue me in  ???
Re: got troubles
« Reply #1 on: July 10, 2011, 06:37:47 PM »
It probably needs to have the bowl cleaned, varnish can stick needles and
block jets in as little as a year, you might try spraying carb cleaner down
the vent tube and fill the bowl with the spray to get it cleaning, it might even
come back to life without disassembly
Re: got troubles
« Reply #2 on: July 11, 2011, 06:59:03 AM »
thx il give it a try on my next day off
Re: got troubles
« Reply #3 on: July 13, 2011, 01:42:12 PM »
ok well replaced fuel pump because i changed oil and seen more gas then oil in there so i replaced fuel pump and now not getting fuel any ideas and sprayed the whole top part of  the carb with cleaner still nothin so anyideas im think i need to rebuild carb
Re: got troubles
« Reply #4 on: July 13, 2011, 09:36:50 PM »
Not the carb, but down the vent tube to fill the bowl with the cleaner
You might need to check the tank for gunk too, blow air back down the
fuel line and listen for bubbles
Offline oak_raid
  • 193
Re: got troubles
« Reply #5 on: July 15, 2011, 08:35:05 AM »
If you are not getting fuel to the carb with a new pump, there is probably a blockage somewhere.  I had this problem too.  Blow all your fuel lines back to the tank (Be sure to remove the fuel cap!!!).  Once you get those clear (you'll hear air in the tank), if it still aint gettin fuel to the card you know the problem is under the hood.
Before removing the carb for rebuild, one thing to check is where the fuel line attaches to the carb.  Follow the fuel line from the fuel pump to the carb, take the fuel hose off, then remove the nipple it was attached to (you may have to move some stuff to get it off).  Once you get it off, take a light and look inside and see if there is any blockage there.  Mine was packed solid with crap, not letting fuel into the carb.
Its probably not a bad idea, if you've gone this far, to go ahead and drop your fuel tank and clean it out too.
Offline lv2fsh
  • 312
  • 19
Re: got troubles
« Reply #6 on: July 15, 2011, 09:43:16 PM »
Did you disconnect the line at the carb and crank it to see if gas was making it that far?. If it is, there is a sight glass on the front of the carb for the float bowl. If you don't see any, you may need to rebuild or clean the carb. There is a screen filter inside the carb before the float. I have taken off the fuel line and sight glass and sprayed carb cleaner in it and got ti to run after the same problem. Try this too.
http://bbs.zuwharrie.com/content/topic,21551.0.html
Re: got troubles
« Reply #7 on: July 19, 2011, 04:42:39 AM »
ok well not any of those lol it was the fuel pump rod is stuck in head well im saying forgett that blocked it of and waiting for payday for ele pump
Offline Breeze-O-Top
  • 89
    • Breeze-O-Top Safari and Bikini Tops.
Re: got troubles
« Reply #8 on: July 25, 2011, 10:08:48 AM »
Try the Hillbilly carb rebuild. If you can get it running by putting some (a little) gas down the carb , cover the carb with your hand to create a large vacuum. It may suck the junk out. Remember to remove the little threat bolt that the cover screws into so you get a good seal. :)
Owner of breeze-o-top.com
Stock motor, K&N air filter, MSD Blaster Coil, 30" tires.
4:16 gears with front and rear Lockright Lockers. Old Man Emu springs and a mild lift. Custom angle iron bumper, army ammo can storage. Petroworks dual friction clutch. CB & 2 meter ham radio. And other fun things!
Re: got troubles
« Reply #9 on: September 07, 2011, 12:14:12 PM »
well ive been gone for awhile but i tryed what you said and it ran as long as i kept my hand on it but after i let off it would idle up and shut off any ideas guys
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: got troubles
« Reply #10 on: September 07, 2011, 12:29:23 PM »
Also mine had same issue after I put new gas, sea-foam in tank, carb, replaced fuel filter I finally removed the inlet that is gas going to carb and cleaned it out there was chips, dirt, many things cause a blockage.  after that my float was dirty but sea-foam cleaned her out real good.  Just another thing you can check thats simple, goodluck!
Re: got troubles
« Reply #11 on: September 07, 2011, 12:47:13 PM »
ill give it a shot thxs
Re: got troubles
« Reply #12 on: September 08, 2011, 09:55:59 AM »
ok well blow out fuel lines  but i also droped tank and daang that thing is rusted so new fuel tank here i come
Re: got troubles
« Reply #13 on: September 08, 2011, 08:05:04 PM »
there is also a check valve in one of the lines by the fuel filter you might want to clean.
Re: got troubles
« Reply #14 on: September 24, 2011, 01:38:11 PM »
ok well put in new tank well not new but cleaned out and resealed old one filled it up and still no running so im lookin for a weber
