Need help with front axle!
  • 19 Replies
  • 2753 Views
Offline XEARLX
  • 62
« on: July 10, 2011, 03:27:52 PM »
alright so here's the deal.
I have a stock front axle off a doner samurai. I took the hub off to get to the drive shaft to then find that the rotor housing was sealed and so was the axle....... i tried pulling the pumpkin apart to remove the C clamp and pull the drive shaft out but i cant seem to get the ring and pinion out.
Please if you have any info or can help please let me know ASAP.
Thank you, Earl
Offline Jluck
  • 1389
  • 40
Re: Need help with front axle!
« Reply #1 on: July 10, 2011, 03:36:48 PM »
you have to get both axles out of the knuckles before you can pull the third member out. and there are no c-clips in the front axle (I think that's what you meant). pics would be very helpful.
Offline XEARLX
  • 62
« Reply #2 on: July 10, 2011, 04:49:20 PM »
here's where i am stuck..............
Offline Jluck
  • 1389
  • 40
« Reply #3 on: July 10, 2011, 08:02:19 PM »
spin those axles around until they will pull straight out. there is a flat spot machined on the birfield that has to be in a certain spot to pull them out.
Offline XEARLX
  • 62
« Reply #4 on: July 10, 2011, 08:13:55 PM »
Do I have to spin them both at the same time, and in the same direction?
Offline Jluck
  • 1389
  • 40
« Reply #5 on: July 10, 2011, 08:18:39 PM »
nope, one at a time is fine.
Offline XEARLX
  • 62
« Reply #6 on: July 10, 2011, 08:39:34 PM »
Alright cool. I'll let you know how I make out.
Thanks man
Offline Jluck
  • 1389
  • 40
« Reply #7 on: July 10, 2011, 09:42:18 PM »
Thanks man
thats why were here. :)
Offline XEARLX
  • 62
« Reply #8 on: July 10, 2011, 10:40:45 PM »
worked out perfectly. tomorrow i take apart the hub and broken axle shaft and replace it with the doner and i will soon again have 4 wheel.
Thanks again for the help! ;D
« Reply #9 on: July 10, 2011, 11:41:09 PM »
man I have to get my eyes checked out, the front spring perches look like they are turned like 20 deg. from one another.
Offline XEARLX
  • 62
« Reply #10 on: July 11, 2011, 08:07:14 AM »
that's just how i had them pointed. there wasn't anything wrong with them. they were just pivoted in different directions. 8)
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #11 on: July 11, 2011, 08:11:40 AM »
Wait, what? They should not be able to move at all?
Offline Jluck
  • 1389
  • 40
« Reply #12 on: July 11, 2011, 09:42:57 AM »
HOLY SMOKES!!! I missed that (using phone). get that where it need to be and welded on.
Offline XEARLX
  • 62
« Reply #13 on: July 11, 2011, 12:31:16 PM »
they're pivotal, im not sure why they're like that but ive seen a couple front axle shafts like that so it doesnt worry me. i know the rear axle shafts are straight.
« Reply #14 on: July 11, 2011, 10:19:06 PM »
You might want to index them when you get the axles installed
and the drive shaft in, then burn them into place
