what size tire on a 2dr tracker
  • 18 Replies
  • 5120 Views
Offline mattstracker
  • 43
Re: what size tire on a 2dr tracker
« Reply #15 on: July 24, 2011, 08:28:45 PM »
I am running 513 gears with an auto trans.
« Reply #16 on: July 25, 2011, 09:03:52 AM »
The automatics really work good in off road conditions, because you can creep without burning out the clutch.  I have been running 30X9.5X15 M&S for a couple years (and many modifications).  I found my tires & rims at a 4X4 swap meet, which were in very good condition.  They weren't as big as I thought I wanted, but price and condition won me over.  My 8v pushed them without many issues, and then then lifts & mods. began.  We are running the same size tire on Drone637's race car, with stock rims.   Drone637 is running 235X15 on his DD with more of an Hwy/AT tread.
When you start to lift it, 4 door springs will give you about 1"+ (depending on condition/use of springs), and are a straight swap out , giving just a little more clearance for a low price.  I feel that the heavier springs produce a better ride than the coil spacers, but it is more experimental than just Ordering a Spacer Kit.  Jeff and Mudchild have kits to fix any clearance issues you may develop with either of the tires you questioned about.
Offline tdrrally
  • 42
« Reply #17 on: July 25, 2011, 02:32:57 PM »
i'm not into creeping ,more going fast
my auto has a hard time moving with 215/70s
but once it starts going its ok
  • 43
« Reply #18 on: August 01, 2011, 06:55:58 PM »
mine is a daily driver a lot better fuel mileage that my 2000 Z71. That is why I am looking for mileage. I think I am gonna go with 225/75/ 15. In the Wintermark Steel Radial HT it is a M+S tire.
