what size tire on a 2dr tracker
  • 18 Replies
  • 5115 Views
Offline mattstracker
  • 43
« on: July 08, 2011, 06:31:22 AM »
I have a 96 2dr tracker. Iam going to put a little bigger tires on it. What size would be best I still want pretty good gas mileage.   But i want the biggest i can go with no lift. Iam going to go with a 235/75R15 or a 225/75R15. which would you go with?
Re: what size tire on a 2dr tracker
« Reply #1 on: July 08, 2011, 07:45:24 AM »
I've got 235/75/15 on my Sidekick (on 15x7 wheels) without a lift (although that's going to change soon). There's a bit of rubbing at full lock, but not much. I considered trying to shoehorn 30s, since I was going to lift it anyway, but went with the 235s, as I got a good deal on 'em.  8)
- Andy
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Offline fuzzy1
  • 350
« Reply #2 on: July 08, 2011, 11:52:46 AM »
Yeah 235's will be okay, I got just some scrub on the plastic inner fender liner up front... but only in tight turns, ie parking lots. Depends if you're going to use stock rims too, IMO 235's are too wide for the stock rims' 5.5" width. BFG recommends 6-7" rim width for their 235/75R15 AT. I still get a tiny scrub even after the OME lift settled in, but not enough to worry about.
Hth,
Fuzz
Non Illegitimi Conterat
  • 43
« Reply #3 on: July 08, 2011, 02:59:39 PM »
I will be mounting them on 15 X 7 i think I am not sure how wide they are.
Offline Jluck
  • 1389
  • 40
« Reply #4 on: July 08, 2011, 03:02:29 PM »
- Andy
whats the size difference between 235's and 30's? (almost none) ;)
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: July 10, 2011, 05:19:54 PM »
I've been running 225's for several years.  There is no rubbing, and almost no effect on the fuel mileage unless you go by the manufacturer's tire pressure recommendations.  The sticker on my '96 recommends 23psi.  At that pressure, the mileage drops to the low 20's (typically 23MPG).  Pump them up to 32psi, and you get high 20's (around 29MPG).  It rides like a brick on a roller skate, but tread wear is still pretty even, after about 50K miles.  Off road, the 225's seem to do best at about 15psi, especially on gravel and sand.
Jim Z.
66 Apache camper
  • 43
« Reply #6 on: July 11, 2011, 09:22:33 PM »
do  you guys think that a 225/75/ 15 will be fine on a 7 inch rim?
Offline stock93tracker
  • 309
« Reply #7 on: July 11, 2011, 09:26:27 PM »
They should, yes.  Heres mine on 15x7" wheels with 235/75/R15's with no lift.  Loved the stance at this point, probably my favorite in the time i had it.
http://memimage.cardomain.com/ride_images/1/2058/2841/5143920025_large.jpg
93 Geo Tracker
-2" Lift
« Reply #8 on: July 12, 2011, 07:51:35 AM »
- Andy
Well, one has threee numbers the other has two ...   :D
One difference was that it was much easier to find a set of used 235s vs. 30x9.5s (if you go that route). But yes, very little difference at all.
- Andy
Offline Rubberducky
  • 84
  • 1990 sidekick 3" Calmini Sus Lift ARB
« Reply #9 on: July 19, 2011, 09:56:02 PM »
Yes. not much difference 235's to 30's but if you want a more aggressive tread then the 30''s give you more options.
« Reply #10 on: July 23, 2011, 12:54:43 AM »
The difference is 1.1 inches, according to the calculators.  But that .55 inches of clearance makes a big difference.  We run 30x9.5" tires on project trouble, and both fenders and smashed up about 1/2" after a few hard landings with stock front 4-door springs.  But I don't have clearance issues anymore.  :D
Offline Jluck
  • 1389
  • 40
« Reply #11 on: July 23, 2011, 01:18:35 AM »
All tire manufactures charts I have saw have been .2 or less difference in diameter between 235's and 30's. I have been told alot of the same components are shared during making of the two sizes
Offline adnan
    • yoga san francisco
« Reply #12 on: July 23, 2011, 02:47:08 AM »
Thanks! This is something I've really missed and was very happy to find. :)
 *Link Removed*
Offline tdrrally
  • 42
« Reply #13 on: July 24, 2011, 03:15:58 PM »
what gear are you running with a 235?
is it an auto or manual trans?
« Reply #14 on: July 24, 2011, 05:46:04 PM »
Don't worry about the difference.  Both of them BEG for a little lift after you have them on.  Just like the little bit bigger tires, the little bit of lift comes next.  Then for some reason a stock Tracker just looks a little anemic.
Both rob a little power, which will be compensated by a little higher rpn's each gear.  They do seem to give you more traction, mostly because of a more aggressive pattern.
