Undertaker Sidekick / Tracker Underdrive question
  • 2043 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: July 05, 2011, 11:47:20 AM »
i have a 98 sidekick sport 1.8L and
i was wondering it says 33" with 4.62 gearing
would i still be good for highway if i used 5.12 gearing?
and this undertaker is in affect all the time right? not just in low range..
.Dml-
Re: Undertaker Sidekick / Tracker Underdrive question
« Reply #1 on: July 05, 2011, 04:56:19 PM »
Yes, the undertaker is a full time reduction box.  I think hitting a gear calculator is going to be your best bet for deciding on gearing.   It will allow you to see how far off the gearing is.  Or you can just divide the two together to see how far off you will be from expected gearing.
For example, if your gearing is supposed to be 4.62 and your running 5.12 you will be 10.8% off.  So you will be 10% fast on your speedy.
Offline my996duc1
  • 222
« Reply #2 on: July 05, 2011, 05:13:41 PM »
here is a good gearing calculator : http://www.grimmjeeper.com/gears.html
« Last Edit: July 05, 2011, 05:15:46 PM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
