My XL-7 has aluminum front diff housing...is this normal?
  • 1553 Views
Offline Jluck
  • 1389
  • 40
« on: July 02, 2011, 09:28:07 PM »
I thought my XL-7 would have the steel diff housing. is this the case for all of them? ???
Re: My XL-7 has aluminum front diff housing...is this normal?
« Reply #1 on: July 02, 2011, 11:45:27 PM »
They only had steel '03 and after I think.  Even then it may not be for both stick and auto.  My '02 is aluminum also.
Offline Jluck
  • 1389
  • 40
« Reply #2 on: July 03, 2011, 05:49:10 AM »
thanks.
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: September 04, 2011, 08:24:40 AM »
I haven't found or seen a first gen XL7 with a steel front housing. When I broke mine 8 yrs ago, I found a Vitara steel front complete (housing, mounts, drop center). Went to transfer the drop center section (aluminum), but my ring was chipped. Couldn't find a good set of 5.13's, so had to order a new set through local Suzuki dealership (yah, tried Hawk, Rocky, Spidertrax). Put them in the Vitara center section, installed it in, and haven't had any trouble in 8 yrs. Hitting 120k. Did have manual lockouts on for several years till last year when my kid was using the XL7 as a school commuter.
Biggest issue I've had with the XL7 is the front brakes. I'm on my 4th set of pads and second rotors. Still have original rears. Lots of weight transfer when braking.
Recently, the rear ac has been leaking at their firewall connection.
Lenexa, KS
Offline bush buster
  • 263
« Reply #4 on: October 20, 2011, 01:59:53 PM »
thanks.
Also 20003 is a crossover year meaning they used up all the old aluminum diffs before they started with the steel ones.  I know this because i ordered a 2003 xl7 diff for my vitara from out of town and was dissapointed to discover it was aluminun. Still beefier than my stock one at least.
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
