Rattling Cat
  • 1114 Views
Offline 144man
  • 85
Rattling Cat
« on: July 01, 2011, 06:07:30 PM »
My '87 Sammy has developed a rattle on hard acceleration.  It sounded like a loose heat shield somewhere, but on further investigation, it seems that the core of the catalytic converter is loose in its housing.  The entire exhaust system is tight as a drum, but when I thump on the cat, I can hear a rattle.  Do I need a new cat?
Offline lv2fsh
  • 312
  • 19
Re: Rattling Cat
« Reply #1 on: July 01, 2011, 08:07:15 PM »
Sounds like you do need a new one. If those loose pieces plug it up, it may not run and won't run very good if if does.
Offline my996duc1
  • 222
Re: Rattling Cat
« Reply #2 on: July 02, 2011, 04:03:46 AM »
change it quick.... I waited and drove mine for awhile. It ended up blowing pieces into the muffler. Then I ended up having to change both.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
