Technical Discussion - Performance / Modify
trans. coolers
trans. coolers
vw505
133
trans. coolers
June 26, 2011, 05:48:51 PM »
Were do you all have your after market trans. coolers mounted. Im thinking of this one.
wildgoody
8134
67
Re: trans. coolers
June 26, 2011, 08:21:56 PM »
I used a more traditional flat one, put it in front of the intercooler
vw505
133
Re: trans. coolers
June 26, 2011, 10:04:52 PM »
Does any one have a photo of how they have there cooler.
tictac
38
What's THAT noise now?
Re: trans. coolers
Reply #3 on:
June 27, 2011, 06:48:12 PM »
ive seen similar set ups on drag cars, but they used it for oil. needs airflow on it. good heat sink, but will still need some air flowing. on the drag car it was on frame. not so sure good idea to mount like that on a 4x4. might rip off.
94 Sidekick. Calmini 3" lift with EDSES. 2.0 engine swap (real soon) 😎
Drone637
8121
116
Evil Cow
Re: trans. coolers
Reply #4 on:
June 28, 2011, 11:27:44 AM »
Check out replacement radiators. A lot of them have built in oil coolers.
BRD HNTR
2300
56
Re: trans. coolers
Reply #5 on:
June 28, 2011, 10:06:02 PM »
I had my 6 x 10 mounted behind the radiator, because I use an electric fan, and didn't want to loose motor cooling capacity. I had to go to a bigger radiator, so I got one with cooling coils.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
