95 Sidekick 4 dr 4x2 headers?
  • 2011 Views
Offline Zuki-Girl
  • 128
« on: June 25, 2011, 01:54:35 PM »
Anyone know if they make a shorty header to replace stock exhaust manifold? Third one has cracked at number tube,tired of getting the junkyard crap .
Offline tictac
  • 38
  • What's THAT noise now?
Re: 95 Sidekick 4 dr 4x2 headers?
« Reply #1 on: June 25, 2011, 03:02:25 PM »
I never seen a short one.  I have a thorley on my 8v.  I assume yours is a 16v.  they make a header that replaces the manifold and down pipe.  every manifold I have ever seen cracks.  not sure why either.  mabye the material its made of isnt good quality.  but a header should solve that problem.  I have seen some of the vendors sell them.  I got mine from summit.
94 Sidekick. Calmini 3" lift with EDSES. 2.0 engine swap (real soon) 😎
Offline Zuki-Girl
  • 128
« Reply #2 on: June 26, 2011, 03:22:02 AM »
OK ju8st thought I'd check and see. I remember when I had my Bronco,a couple different companys made them for that.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #3 on: June 26, 2011, 08:34:02 AM »
If you have a 16v your in luck 8v all I've seen is long Tobe http://www.puresuzuki.com/16v_header.htm
« Reply #4 on: June 26, 2011, 10:04:05 AM »
calmini makes a short 16V header.  I had one on my 92 16V...until it rusted/corroded between where all the tubes come together. ::)
« Reply #5 on: June 28, 2011, 07:34:32 PM »
thorley header or one of my used exhaust manifolds. if you have gone throught three there is a issue that is causing it. the new header and or manifold will have the same issue.
if you would like additional assistance email me, i will post ideas if you need assistance...
Offline Zuki-Girl
  • 128
« Reply #6 on: June 29, 2011, 01:42:12 AM »
Even alot I've seen in the u-pull yards have the same issue in the same spot. I'm thinking a design flaw in the manifold.
Offline tictac
  • 38
« Reply #7 on: June 29, 2011, 03:49:43 PM »
me too.  I put a new manifold on and it cracked in 2 months on cyl 1.  i welded a bung in down pipe and checked with a wideband if it was getting lean and cracking.  no lean.  so installed thorley header, no problem for months now.  I put header on in november and no leaks or cracks now.  plus it was jet hot coated.
Offline kreator
  • 634
  • 15
« Reply #8 on: June 30, 2011, 08:04:09 AM »
nomater whos header you get if it is not coated take it to a ceramic coater and get it done, it will last a lot longer and is worth the money
