Methods of Flexing your Suspension
  • 1540 Views
Offline mbruce
  • 139
« on: June 22, 2011, 05:19:56 PM »
I'm doing a RUF and will eventually get to the point where I measure my flex to determine what shock size I need
How do you all measure your flex?  I read where it's ideal to drive up a 20 degree ramp until one of the 3 grounded tires lift from the ground -- then do a measurement and etc...  Is there a quicker way with a jack?
Ignorant questions lead to a wealth of knowledge
Offline mike5721947
  • 545
Re: Methods of Flexing your Suspension
« Reply #1 on: June 22, 2011, 08:55:23 PM »
most use a forklift, but when you dont have one you can always take the trusty highlift jack and a ratchet strap or chain on the rim of one of the tires. then jack up till a tire lifts off the ground. or if you have an over head lift or a hoist you can do that way too. but lift from the tire, that way you get the max flex out of it.
31" kumhos 3inchs of lift.
Offline mbruce
  • 139
« Reply #2 on: June 23, 2011, 04:00:29 AM »
Cool - I have a forklift ...ya just put the forks under one of the tires and pick up until another tire lifts ?
« Reply #3 on: June 23, 2011, 12:43:08 PM »
That about covers it.  Make sure you don't flip her rover.  :D
« Reply #4 on: July 01, 2011, 08:17:54 AM »
Ramps on loading docks work good too  ;)
