Removable Doors for a Tracker
  • 6281 Views
Offline CodyB
  • 16
« on: June 17, 2011, 11:44:44 AM »
I need some ideas for a way to make the doors on my tracker removable.  I have a 93 tracker and i would like a quick and easy way to make the doors removable without completely unbolting them.  And I would like to make a set of tube doors also. Do you guys have any ideas or suggestions?
Re: Removable Doors for a Tracker
« Reply #1 on: June 17, 2011, 02:33:13 PM »
There are two types of hinges, one type has a circlip holding the pin in, the other type is more like a rivetted end. The pins can be a pain to remove because of paint on the pin and because one end is knurled. I recommend unbolting the hines to get the pins removed. If you have the rivet type then replace them for the circlip type. Clean up the pins to remove all the paint and file down the knurling. The pins should then be relatively easy to push in and out and the doors can be easily removed.
Offline CodyB
  • 16
« Reply #2 on: June 18, 2011, 10:32:32 PM »
Alright ill give that a try. Anyone know if you can buy tube doors for a tracker?
« Reply #3 on: June 20, 2011, 07:57:56 AM »
I have never seen them for sale. I have see a couple of Kicks with custom made tube doors on them.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #4 on: June 21, 2011, 12:50:51 PM »
When you take off your doors, be careful the metal limiting strap/spring thing doesn't fall into the door.  It's a pain in the neck to retrieve.
XL-7 front coils
1.5" rear coil spacers
Offline ranger88den
  • 279
« Last Edit: June 22, 2011, 09:45:40 AM by ranger88den »
