Adjust the throttle cable on a 2.0L I4?
  • 9 Replies
  • 3228 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: June 11, 2011, 10:43:21 PM »
Noticed the other day that the Tracker's throttle cable is a bit slack up at the top of the engine where it connects to the throttle body.  You can move the lever a bit before it actually pulls on the cable.  This might explain some of the low speed bog it has.
Checked the pedal end in the cab and it's just fine, nice and tight like it should be.
How do I adjust this?  Loosen then tighten the threaded end there?
Offline IanL
  • 466
Re: Adjust the throttle cable on a 2.0L I4?
« Reply #1 on: June 12, 2011, 01:35:06 AM »
2 to 7mm slack - adjust on the nut.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: June 12, 2011, 12:09:08 PM »
Okay...can you put that in English...errr...stupid...errr...explain that better?
Last time I adjusted a throttle cable it was using zip ties and it was a Ford.
« Reply #3 on: June 12, 2011, 06:37:39 PM »
If I recall correctly, my 2.0 GV has a bracket that allows the outer casing of the cable to be adjusted to get rid of that slack - if you have an automatic, you may need to readjust the kickdown cable as well.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: June 12, 2011, 07:21:41 PM »
2.0L inline 4, 5 speed stick.
Offline IanL
  • 466
« Reply #5 on: June 13, 2011, 12:44:59 AM »
The accelerator cable play should be 2 to 7 mm, measured by movement of the pedal.  The adjustment is made on the throttle body end.  Identify the accelerator cable, slacken the locknut and adjust the adjustment nut to achieve the above pedal movement.  Retighten the locknut.  Stow tools.
« Last Edit: June 13, 2011, 12:49:29 AM by IanL »
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: June 13, 2011, 04:31:29 AM »
The pedal honestly doesn't seem to have any play.  I climbed under the dash and watched and moving it seems to move the cable instantly.
Which sounds odd as I type it but sure seems like the slap is at the other end only.
Offline IanL
  • 466
« Reply #7 on: June 15, 2011, 01:19:45 AM »
Accelerator cable play should be visible (in terms of cable slack) at the throttle body end of the cable, where it attaches to the throttle arm; you only measure it at the pedal.  You move the pedal to take up the slack at the TB end, and measure how much it moved.
« Last Edit: June 15, 2011, 01:23:06 AM by IanL »
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: June 15, 2011, 06:30:32 AM »
Guess it's tight then.  Not slack at all at the pedal.
Thanks guys.
Offline IanL
  • 466
« Reply #9 on: June 19, 2011, 02:00:18 AM »
If you can't take up the slack at the throttle end by moving the pedal, the cable is binding.
