wheel size
  • 1600 Views
Offline stovokor
  • 27
wheel size
« on: June 10, 2011, 04:23:46 PM »
i want a wider wheel  (looks more then anything else)   what size   i.e. 15x7 or 15x8  would fit/be the better choice on my samurai the tires i have are 235/75r15  i have only a 2 in shackel lift  also what back spacing 50/50?
Re: wheel size
« Reply #1 on: June 10, 2011, 11:21:31 PM »
I would go with a 7 in max for 235 rubber
Offline woof359
  • 111
Re: wheel size
« Reply #2 on: June 12, 2011, 01:25:07 PM »
i have a set of 15x8 off a 70s cj on mine with 235 tires. a calmini shackle lift and they work great.
CHUCK AND MICHELLE
Offline Capt
  • 738
  • 28
Re: wheel size
« Reply #3 on: June 13, 2011, 06:14:58 AM »
If you swap rims, check your "Back Spacing" as it may cause your steering to "Rub" the spring
on hard turning. Or too much and your left arm is going to get "Highway Freckles" from all the
gravel & mud coming up the side from the front tires. (Wider Flares is the usual cure)
CAPT
Offline wachtelhund
  • 32
Re: wheel size
« Reply #4 on: July 04, 2011, 07:43:04 PM »
I've also been looking for new wheels for my zuk.  Came across this site with very good prices. http://www.buywheelstoday.com/search/wheels.asp
Dave
Samurai
made in Japan
Built in the USA!
Offline javariajee
    • Acne masque
Re: wheel size
« Reply #5 on: July 05, 2011, 12:07:23 AM »
Thank You for the info. on surveys. I just might give it a try.
 *Link Removed*
