What goes here?
  • 1396 Views
Offline FreddyDynamite
  • 42
What goes here?
« on: June 08, 2011, 06:58:19 AM »
Just bought this 91 and doing all the regular tuneup stuff, but I noticed this and I am not sure what goes there.  Any help or pics would be appreciated, thanks
Re: What goes here?
« Reply #1 on: June 08, 2011, 08:00:25 AM »
Check the PCV that goes into the manifold.  That might be it.
  • 42
Re: What goes here?
« Reply #2 on: June 09, 2011, 05:59:12 AM »
I am thinking this is a part that was "recycled" from another vehicle, looked around for engine pics and from what I can see, this is normally just a single hose going from the valve cover to the throttle body cover.  Can anyone confirm this?
Re: What goes here?
« Reply #3 on: June 09, 2011, 08:03:51 AM »
I think you are right, I don't remember any other hoses in that spot
on the '89 Kick, it goes from the valve cover, into a T that has a small
port to the base of the throttle body, and then comes up to hook into
the aluminum intake tube for oil vapor recovery
Re: What goes here?
« Reply #4 on: June 14, 2011, 08:12:44 AM »
That is a factory piece.
One port is connected to the nipple on the topside of the coolant tube, that is on the backside of the water pump.
The other port is connected to the bottom of the IAC valve (idle air control).
  • 42
Re: What goes here?
« Reply #5 on: June 15, 2011, 01:12:34 PM »
Thank you Skyhiranger, the pictures are always for...a whole bunch of words
Re: What goes here?
« Reply #6 on: June 15, 2011, 01:45:20 PM »
No problem. ;)
