Summer and no A/C in tin top. Is it real bad?
  • 19 Replies
  • 2024 Views
« on: May 30, 2011, 03:03:58 AM »
I have an 86 tin top with no A/C. Wondering if it's a bad idea to go out in the desert here in SoCal in the summer? What is your experience going out with no A/C on hot days?
Offline DonD
  • 140
Re: Summer and no A/C in tin top. Is it real bad?
« Reply #1 on: May 30, 2011, 05:56:34 AM »
My experience has been, I tend to sweat a lot.   >:D
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
« Reply #2 on: May 30, 2011, 08:05:59 AM »
LOL. I don't mind the heat too much but my wife tends to shrivel up in the heat. Wondering if it is really unbearable or typically not too bad? I did fix the fan switch in our Samurai so air blows from the vents now. I guess I could mount a mister bottle in front of the vent for her...
« Reply #3 on: May 30, 2011, 08:23:55 AM »
Was I the only one wondering when Zig got married for a minute there?
Offline DonD
  • 140
« Reply #4 on: May 30, 2011, 08:53:47 AM »
A good thick headliner and white top helps!
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
« Reply #5 on: May 30, 2011, 10:56:11 AM »
The old Rovers used a tin sheet over the top of the roof with some ~1/2 to 3/4" spacers
as a heat shield, I would think that could help you too, and adding some insulation to
the inside would be good.
The extra tin on top is like a heat shield around a turbo, it stops the "microwaving" effect
of the heat that you will feel if you don't have it or good roof insulation.
Offline Jluck
  • 1389
  • 40
« Reply #6 on: May 30, 2011, 11:53:35 AM »
I ran this scenario through my top secret calculator and found the following:
A:
A happy and comfortable wife is worth more than the time/trouble to install A/C.
and
A wife that actively has fun/comfortable wheeling experience is less likely to bitch at "honey I just have to have this for my...." expenditures.
I might start selling these new calculators. :)
Offline locjaw
  • 2045
  • 22
« Reply #7 on: May 30, 2011, 02:57:11 PM »
he got me the other day!
« Reply #8 on: May 30, 2011, 04:24:11 PM »
I did put some foam floor insulation inside as a roof liner to stop heat/cold from radiating through as much. I like the idea of painting the top of the roof white! That should help a lot. It's been rolled once already so cosmetic appearance is not a top priority. Just finished this morning replacing the rear axle bearings and seals, rear brakes and wheel cylinders, and got the mini spool installed. Wife wanted to go out so I had to stop before I got a chance to bleed the brakes. Hate being that close to finished and not finish the job.
Here is my Samurai.
BTW, who is Zig?
« Reply #9 on: May 30, 2011, 05:11:17 PM »
Zig is a long time ZukiWorld member, Bryan Zeigler and his user handle is Zukipilot
so you see the confusion your user name can cause
« Last Edit: May 30, 2011, 05:16:01 PM by wildgoody »
« Reply #10 on: May 30, 2011, 08:24:06 PM »
I registered first, or thought I did, under another name. Not sure what happened but I think I didn't get the registration activation email. I wonder if I can change it to the original name I wanted?
« Reply #11 on: May 30, 2011, 08:45:31 PM »
Not to worry, but he was registered Mar-24-2003, just a few years before you  ;)
Actually he is a member of the ZukiWorld Online Staff. We have been neck and
neck for the title of ZukiWorld Loudmouth for the most posts on the forum for
years now, I have lost count, but we are both up there
« Reply #12 on: May 30, 2011, 09:39:25 PM »
I was able to recover my original user name password! It was about 18 months ago when I registered and I forgot I had actually even made a couple posts here already. Dang, my memory is shot.  :-\  So I will retire this name and continue to use my original name which is PilotSmith. Don't want people to start wondering why Zig is asking so many newbie questions.   :)
« Reply #13 on: May 30, 2011, 09:42:45 PM »
Ok, glad I got that all cleared up!  :)
Offline Jluck
  • 1389
  • 40
« Reply #14 on: May 30, 2011, 10:18:39 PM »
much better, thanks. ;D
