4WD ISSUES 1998 CHEVY TRACKER 5 SPEED
  • 9 Replies
  • 2758 Views
Offline umiami80
  • 39
« on: May 26, 2011, 05:54:42 AM »
Re: 4WD ISSUES 1998 CHEVY TRACKER 5 SPEED
« Reply #1 on: May 26, 2011, 08:02:07 AM »
It sounds like you might be having issues with your differential
pressure or vacuum actuator, I can't remember which way it works.
Check the lines for leaks, or you can replace the actuator diff for a older
standard unit that does not require the actuator, and add the lockout hubs
to the outer where you have drive flanges now
Offline umiami80
  • 39
« Reply #2 on: May 26, 2011, 10:10:14 AM »
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: May 26, 2011, 11:33:43 AM »
Wild, 98 in the US shouldn't have any kind of vacuum actuator in the diff.  Standard gears, shafts, and hubs with manual or auto hubs.  99+ have the vacuum crap.
« Reply #4 on: May 26, 2011, 12:30:52 PM »
OK, scratch my thoughts, I thought 98 was the change over year, isn't that the
year the new body style came out too?
Offline umiami80
  • 39
« Reply #5 on: May 26, 2011, 12:53:14 PM »
My Tracker is my Avatar.  It is the same as the 1995-1998.  The Chevy Tracker is the first year Chevy put its name on it but still the older style.  Still believe it could be my hubs?  I think the noise is coming from there.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: May 26, 2011, 03:00:18 PM »
Everywhere but here.
In North America we kept the square body a year longer than everywhere else.
Offline Foot
  • 76
  • Nothin Like It
« Reply #7 on: May 29, 2011, 08:22:30 PM »
Yeah it deffinately sounds like you have a auto hub problem. You can pull them apart and check to see if there is any damage or ware, but you would be better off changing to manual while you have it apart.
HIT IT !!
Offline fireman2828
  • 26
« Reply #8 on: May 30, 2011, 05:05:27 AM »
Mine does something similar. If I don't start out in 4wd then shift to 2wd it makes that sound.  Is it hard or expensive to switch to manual hubs?
1990 Geo Tracker 4x4, 5sp.,
Auto locking hubs.
First tracker ever owned. Purchased 3/2011
Want a Samurai
Offline Foot
  • 76
  • Nothin Like It
« Reply #9 on: May 30, 2011, 01:00:22 PM »
Not if you can find a used set. There's lots of companies now that sell used parts on here not to mention forum members. As far as install it's pretty simple. If I'm not mistaken theres a write up on here that tells you how.
HIT IT !!
