what parts can I use from a 95 tracker on my 88.5 samurai?
  • 1119 Views
Hi guys,
Just both my first Samurai, have wanted one for a while.  Guy I bought it from told me about a 95 tracker parts truck, it has the 1.6 16V so I could get all of the harness, engine, etc.  What other parts will interchange?  Differentials, transfer case, instrument cluster, drive shafts, power steering maybe?  tracker is auto, sami is manual
thanks,
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: what parts can I use from a 95 tracker on my 88.5 samurai?
« Reply #1 on: May 18, 2011, 10:11:43 PM »
the power steering and motor swap the front third member will bolt into the front or rear samurai axles  different gears ratio tho
you could use the front brakes off the tracker on the samurai all i can think of
to use the power steering you have to mount the punp up higher on the 16v mod the steering shaft  and drill and sleeve the frame to mount the steering box took me a day to install well worth it
