Since I got rid of my sammies I thought I would clear out some shelf space. I have more stuff and will be adding as I find it /have time.
Samurai Stuff
88.5 Samurai 1.3 Radiator. Some bent fins,dirty but no leaks. Plastic/aluminum version. $25.00
Samurai hot air tubes for carb. Both for $5.00
Samuria 1.3 intake hat. $5.00
Samurai Transmission Shifter $5.00
Samurai T-case shifters $5.00 each
Samurai intermediate drive shaft. Good U-joints $15.00
88.5 Samurai master cylinder. $10.00
2 Samurai distributors $20.00 each
88.5 Samurai A\C Compressor. $20.00
Samurai carb and intake $25.00
1.3 Valve covers $5.00 each
1.3 Oil Pump $5.00
Set of hombrew strengthened Samurai T-case arms $25.00
Samurai drive line spacer $15.00
Rear Samurai stock 3rd member. Probably best for parts. All gears good, no bearing races and has been sitting on the shelf for a few years. $10.00
Petroworks GM alternator bracket. I had this on a 1.3 Samurai. $25.00
For another $25.00 I will throw in a brand new rebuilt GM 94 amp alternator. NOT A 1 WIRE.
