Knock on wood
  • 1652 Views
Knock on wood
« on: May 21, 2004, 01:27:44 PM »
An hour after telling my friend how GOOD my Suzuki runs, it runs no more.
Help me out. I know it could be a # of things but any info would be appreciated.
I started it up and put it in R. It stalls as I let out the clutch.
I start it up again thinking it was me, tried it again and same thing.
The next ime I try to restart it, nothing. It turns over but will not fire.
I cleaned the rotor and cap but that is as far as my mechanical expertice will take me.
I suspect the fuel pump or filter, maybe the coil.
Any suggestions? Where should I start?
Thanks
Tony (stuck at mall) Balgony
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Knock on wood
« Reply #1 on: May 21, 2004, 01:31:41 PM »
Your on the right path.
I'd check for fuel first.  Thats what it sounds like to me.
If you have fuel check for spark. Pull a plug, ground it and turn the motor over.
Come back with an answer and we'll go from there.
P.S.  What do you drive??
« Last Edit: May 21, 2004, 01:32:11 PM by lil_Truck »
32 MTR's Warn 8000i
Re: Knock on wood
« Reply #2 on: May 21, 2004, 05:41:05 PM »
Its a 92 JLX 4dr.
I will try again la manana.
Tony
Offline Zuki One
  • 441
    • ZUKI - PICS
Re: Knock on wood
« Reply #3 on: May 22, 2004, 08:51:32 AM »
COIL!
;D
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Offline Mike71
  • 1449
Re: Knock on wood
« Reply #4 on: May 22, 2004, 09:03:53 AM »
my moms car did this 01 GV...automatic though it turned out to be the batt....i didnt belive it but my dad was right every time i shifted into gear it would die ran in neutral though..dad charged the batt poped it in and everys groovy
Re: Knock on wood
« Reply #5 on: May 22, 2004, 03:41:16 PM »
Engine ground strap, if it's not there or bad
the Kick grounds the engine through
the clutch cable, and a bad connection
could fry the ignition unit in the distributor.
I think it's called the ignitor by some
makers, I don't know if this has happened
to anyone else, but I fried one on a Toyota
Turdsel  ::) once by unhooking the Bat to
check the alternator :P
Good Luck
Re: Knock on wood
« Reply #6 on: May 29, 2004, 04:40:42 PM »
It was the fuel pump. Man, alot of $!!
Runs like a top now.
Knock on Wood
