Transmission moiunt?
  • 813 Views
« on: May 13, 2011, 06:39:49 PM »
Hey guys I had a F10A 1.0L motor in my samurai and just put a G13A 1.3L in.
The tranmissions dont mount the same to the frame. As far as I know the motor and transmission were both out of an 88 Samurai, the transmission has "87U" on it. Ive ordered an 88 tansmission mount from a local store and it doesnt seem as if it would work, Ill admit I didnt take it home and try it. and Ideas what transmission this is and what mount it requires?
Re: Transmission moiunt?
« Reply #1 on: May 13, 2011, 06:42:08 PM »
Should have used Spellcheck  :-[
« Reply #2 on: May 13, 2011, 11:41:10 PM »
The problem is you have an SJ-410, not an SJ-413 aka Samurai.  So you will need to get a cross-member from a samurai to install, or build your own transmission mount.
« Reply #3 on: May 16, 2011, 03:45:56 PM »
SJ410 body on an 88 Samurai frame. making my own crossmember wont be a problem I just need to know what transmission it is so i know what mount to buy.
« Reply #4 on: May 16, 2011, 09:50:37 PM »
If it's a 5 speed that bolts to the 1.3L then it's a standard Samurai transmission, or SJ-413.  Give Hawk Suzuki a call and they can hook you up with the right mounts.
