changed H2O pump and guess I messed up the timing???
  • 1078 Views
Offline jefftx
  • 8
« on: May 10, 2011, 09:01:41 PM »
I had to remove the timing belt on my 87 samurai to change the H2O pump, now it won't run!! I didn't think i moved the crank or cam pulley so i figured i should just be able to put the belt back on and roll with it ..... no such luck. Would some of you gurus please chime in with what i need to do to try and remedy this?
Are there marks on the sprockets that need to be lined up in a certain way? Please help me out fellas!!
Thanks,   ???
Jeff
Re: changed H2O pump and guess I messed up the timing???
« Reply #1 on: May 11, 2011, 01:03:29 AM »
Yep, crank mark up, cam mark down and distributor at 5 o'clock
firing #1, the real drag is you have to pull the front apart again
This is the factory setting for the 1.6 8V engine, I think it's the
same for the 1.3 but it's been a while since I've done one
Offline rascott
  • 669
  • 15
« Reply #2 on: May 11, 2011, 06:05:48 AM »
1.3L
crank sprocket mark up(mark on oil pump).
cam mark "up"- lines up with notch on the inside timing belt cover. slightly off of straight up.
no slack on drive side of belt.
