Suzuki gearbox
  • 803 Views
Suzuki gearbox
« on: May 10, 2011, 01:44:19 AM »
Hello, can anyone please help me. I have a Suzuki samurai 1.9td, bought in Portugal. It needs a new primary shaft in the (manual) gearbox. Will this part from a Suzuki Santana, bought in England, fit or is the shaft a different size? Thank you for any advice on this problem.
Re: Suzuki gearbox
« Reply #1 on: May 11, 2011, 01:17:12 AM »
Do you mean the shaft between the transmission and the transfer case?
Offline tipover
  • 422
Re: Suzuki gearbox
« Reply #2 on: May 16, 2011, 08:17:04 PM »
Do you have a replacement shaft? If it went out, the gears may be damaged.  You need a press to rebuild it. It way be cheaper to replace it
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Suzuki gearbox
« Reply #3 on: May 16, 2011, 09:09:14 PM »
The gearbox components on just about any SJ413-series Suzuki are interchangable.
There were a few internal changes in the US-version (5th gear ratio, electrical connectors, shifter lever/tower construction) but I do not know if the changes also applied to other countries.
Your BEST choice would be to find a complete transmission from the same year as your Suzuki SJ-413/Samurai/Santana and swap the whole gearbox/transmission.  It is difficult to tell which version is which unless you know exacty what you are looking at.  You should be able to find one at a salvage/breakers yard.
I hope that this helps!
Ack
