How much lift does my new samuria have?
  • 1235 Views
« on: May 04, 2011, 07:15:01 PM »
My new samurai has a hole to hole distance of 6" on the rear shackles, and 5.75" hole to hole on the front. With the stock springs in place, how much lift is this? Thanks.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: How much lift does my new samuria have?
« Reply #1 on: May 05, 2011, 08:25:11 AM »
stock shackles are 2.75" center to center as for how much lift is like this question i got when i worked at a feed store
i have a cow it black and white how much do it weight                       man springs sag over time  is it spoa i dont think we can help much to answer the question
Offline mattlofbc
  • 32
  • Its a GEO thing... I don't understand either
« Reply #2 on: May 05, 2011, 09:45:58 AM »
get a tape and measure from the center of the axle/wheel to the bottom of the fender cutout front and on the rear, the someone with a stock one can give you a measurement maybe.... (more info would be helpful)
'93 Geo Tracker 8V
     Dana 44 SAS 4 Link - 14" travel
     33" Pitbull Rocker's
'96 Geo Tracker 16V
     Custom Bumpers and Cage      29" Goodyear Wrangler MTR's '94 Geo Tracker 8V       5" IFS frame drop and lengthen... NO rear susp or axle at all, its 2x2 off road machine lol      33" Pitbull Rocker's
« Reply #3 on: May 05, 2011, 09:58:10 AM »
If stock shackles are 2.75" and yours are 5.75" then they are 3" longer giving you a lift of 1.5" over stock.  Also if you looked down the page on the forum, someone just asked the stock shackle length. But the best thing to do is like mentioned above measure from the axle centerline to the fender lip.  As long as the fenders havent been cut.  ;D  Then compare to a stock samurai's measurement. This is the best way, just because a spring says it lifts your rig X amount doesnt mean it will.  Your springs can be old and sagging, if your rig has been lightened or has a bunch of junk in it, that could affect your lift...  I had an old Chevy that 4" lift springs lifted my truck almost 5.5 inches.
« Last Edit: May 05, 2011, 09:59:53 AM by trailblazr81 »
