timing jumper
  • 1187 Views
timing jumper
« on: May 04, 2011, 09:53:21 AM »
I have a 94 sammy that pings a little bit under throttle. I want to check the timing to make sure its on..Where is the plug Im suppose to jump to set timing. Is the factory setting pretty accurate or should I advance ore retard it a little..Thanks Dan
Offline Jluck
  • 1389
  • 40
Re: timing jumper
« Reply #1 on: May 04, 2011, 02:00:16 PM »
have you tried higher grade fuel also?
Re: timing jumper
« Reply #2 on: May 04, 2011, 02:24:21 PM »
I have..and it isnt as bad, but the other day i put in reg. gas and it has been pinging like crazy so i just wanted to check my timing to see if its to far advanced..
Re: timing jumper
« Reply #3 on: May 04, 2011, 09:47:17 PM »
It is a little 4 wire (I think it was still a 4 wire in 94) connector by the battery.  It might have a black rubber cap on the end of it, or the cap might be loose.  IIRC, you short the bottom 2 wires, when holding the plug with the tab up.  It should tell you on the sticker under the hood, which wires to short for sure.
I set my samurais at 10* BTDC.  No pinging on regular 87 grade gas.
