Deceleration Mixture Control Valve
  • 1886 Views
Offline jga154
  • 28
    • Jim Arnold Blog
« on: May 03, 2011, 08:10:54 AM »
86 Samurai, 1.3L stock, Cali legal
I just discovered this control valve has a hole worn through the aluminum cap caused by the steel clip that holds the assembly. None of the local parts stores can locate it from their suppliers. I tried online to no avail. Photo included.
Any ideas on where to find something like this?
I have it patched right now an it works but would like to replace it. Thanks.
« Last Edit: May 03, 2011, 12:51:12 PM by jga154 »
86 Samurai Tin top, OME Springs, Bonz shackles, 30x9.50, 4.9:1 TC, rear Lockright locker, Rocky Road Outfitters DIY front bumper
Offline rascott
  • 669
  • 15
Re: Deceleration Mixture Control Valve
« Reply #1 on: May 03, 2011, 01:10:26 PM »
that work the egr valve? looks different than mine.
mabe try hawk- they should be able to get you one.
Offline jga154
  • 28
    • Jim Arnold Blog
« Reply #2 on: May 03, 2011, 01:53:42 PM »
Not part of the EGR. It is called the Deceleration Mixture Control Valve System in the service manual. Supposed to save fuel when you decelerate. I know it won't idle with a hole in the top. Found it for $93.42 at a dealer, ordered it from Hawk used for $25.00.
Thanks.
Offline lv2fsh
  • 312
  • 19
« Reply #3 on: May 03, 2011, 09:40:27 PM »
Had to change mine a wile back. was keeping it from passing smog. Had that same hole.
