Deceleration Mixture Control Valve
  • 1781 Views
Offline jga154
  • 28
    • Jim Arnold Blog
« on: May 02, 2011, 09:00:58 PM »
I just discovered this control valve has a hole worn through the aluminum cap caused by the steel clip that holds the assembly. None of the local parts stores can locate it from their suppliers. I tried online to no avail. Photo included.
Any ideas on where to find something like this?
I have it patched right now an it works but would like to replace it. Thanks.
86 Samurai Tin top, OME Springs, Bonz shackles, 30x9.50, 4.9:1 TC, rear Lockright locker, Rocky Road Outfitters DIY front bumper
Offline jga154
  • 28
    • Jim Arnold Blog
Re: Deceleration Mixture Control Valve
« Reply #1 on: May 03, 2011, 01:41:48 PM »
Well, I found a dealer that can order one. $93.42 ouch. Guess I'll use the patched one for a while. At least till June.
Didn't know about Hawk. Ordered a used one for $25.00.
« Last Edit: May 03, 2011, 01:55:19 PM by jga154 »
« Reply #2 on: May 03, 2011, 10:44:47 PM »
If I had been back on-line earlier I could have told you about Hawk.  They are good for just about any odd Suzuki part.
Offline jga154
  • 28
    • Jim Arnold Blog
« Reply #3 on: May 04, 2011, 09:20:24 AM »
Well, my over fifty syndrome kicked in and I'm just a newbe, so that I forgot about Hawk. I used some stuff NAPA sold me called Q-bond to patch it. Seems to be rock hard just as the advertising says. I'll see how long it lasts before I put the new/used one in.
Also fixed my 4WD switch at the tc with the stuff. It had bare wires right at the top of the unit above the factory resin. It works now too. I'm impressed so far with Q-bond. $$ though.
« Reply #4 on: May 04, 2011, 10:51:54 AM »
How does it compare to the old standard JB-Weld?
Offline jga154
  • 28
    • Jim Arnold Blog
« Reply #5 on: May 04, 2011, 04:34:41 PM »
Maybe faster - 10 seconds  Cyanoacrylate activated stuff
« Reply #6 on: May 05, 2011, 09:32:46 AM »
That makes it sound more like an adhesive then a putty.  Works well though huh?
Offline jga154
  • 28
    • Jim Arnold Blog
« Reply #7 on: May 05, 2011, 05:14:08 PM »
So far, so good. It is labeled as an adhesive and a filling powder. Mine has two colors of filling powder on for metals one for other stuff.
