noise when revving motor
  • 1396 Views
Offline Hubbachubba
  • 19
« on: May 01, 2011, 10:46:03 PM »
i just purchased a 87 samurai it runs and sounds good but if you rev the motor a couple of times , it sounds like there is a loose bolt or nut getting thrown around in the engine or the tranny. it has to rev pretty high in order to make the noise. i removed the flywheel cover to see if there was anything in there, but there was not. if anyone has experienced this before, please let me know. thanks
Offline airmanwilliams
  • 913
Re: noise when revving motor
« Reply #1 on: May 01, 2011, 11:02:44 PM »
could a bearing make that noise maybe?
1993 4door Suzuki Sidekick JX
Offline Capt
  • 738
  • 28
« Reply #2 on: May 02, 2011, 08:31:24 AM »
Noises are Gremlin's and hide in strange places.
I thought I was throwing a rod once and it turned out that the 1 year old  salvagedonor engine was
wallering-out the keyway for the drive sprocket for the timing belt.
There is a resent post on this problem.
CAPT
Offline crgm101
  • 80
« Reply #3 on: May 02, 2011, 05:54:43 PM »
mine was making the same noise sounded like a bolt being thrown around the engine turned out my exhaust coupler right off the header was loose,the part with the 2 springs sorry i dont know the name of it . try that you may get lucky.
Offline Hubbachubba
  • 19
« Reply #4 on: May 02, 2011, 07:22:18 PM »
Well, i drained the motor oil today and it looked good, but when i drained the transmission oil , there was very little and some metal shavings, i think they are syncros. I think i will remove the transmission and rebuild it, has anyone done this themselves, is it possible. Or do i leave it to an expert tranny guy?
« Reply #5 on: May 04, 2011, 09:50:06 PM »
They aren't hard to rebuild.  As long as you have some mechanical aptitude, and a decent exploded tranny pic (or just lay out the pieces in the order of removal) you should be ok.
