Confirming 4wd is working
  • 10 Replies
  • 3116 Views
Offline keith
  • 1176
« on: July 06, 2005, 12:18:49 AM »
I am probably going to Zukimelt this weekend and wan't to confirm that all is well with the 4wd system.  This morning I stopped on gravel in 4wd and gassed it hoping the front tires would spin to show they were under power.  I could get all sorts of spin out of the rears, but none out of the front left, the one I could see from the driver seat.  What is another way I can confirm that all is well?  Preferably from the driver's seat.
« Last Edit: July 06, 2005, 12:19:43 AM by keith »
Offline Uncivilized
  • 1469
    • Car Domain
Re: Confirming 4wd is working
« Reply #1 on: July 06, 2005, 01:07:31 AM »
I get on a loose gravel hill(carpool parking lot) with the hubs locked, gas it in 2wd and it will spin in the rear, then I put it in 4wd and do it again, mine won't spin, it will climb.(if all is well)
« Last Edit: July 06, 2005, 01:08:12 AM by uncivilized »
« Reply #2 on: July 06, 2005, 04:15:48 AM »
You might need to clean and regrease your hubs
Offline jzap
  • 515
  • How difficult can it be?
« Reply #3 on: July 06, 2005, 05:15:21 AM »
Drive it down into one end of the trench on blue trail...  ...If you can drive it out the other end, it's working :) ;D :)...
Seriously, I get hardly any spin out of the front wheels unless we're doing a serious hill climb, or we're on snow.
See you there???
« Last Edit: July 06, 2005, 05:19:07 AM by jzap »
Jim Z.
66 Apache camper
Offline SnoFalls
  • 1358
« Reply #4 on: July 06, 2005, 10:06:18 AM »
put the rear bumper (lifting the rear wheels) on a "stand", drive off it.
Offline ROSS
  • 1412
« Reply #5 on: July 06, 2005, 02:28:24 PM »
PULL THE REAR DRIVELINE AND SEE IF IT STILL MOVES
ROSS
Offline keith
  • 1176
« Reply #6 on: July 06, 2005, 03:11:54 PM »
I jacked up the front and and turned each wheel with the hubs locked.  The driver side does not turn the CV, so I guess I need to work on the hub.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #7 on: July 07, 2005, 09:43:30 AM »
With the t-case in 2wd and the truck parked, lock in both front hubs. Reach under the front bumper and try to turn each front cv shaft. If one still turns, that hub needs work. Neither should turn.
Offline keith
  • 1176
« Reply #8 on: July 08, 2005, 01:37:14 AM »
Thanks for the tip.  I took apart the hub and cleaned it.  It is now working.  I was wondering how I could check it without jacking up the front end!
Offline Digger
  • 1991
« Reply #9 on: July 08, 2005, 05:38:57 AM »
It only works with the tcase in 2wd, in 4wd the front driveshaft keeps the cv shafts from spinning, giving you false results...
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #10 on: July 08, 2005, 09:18:27 AM »
Turning the driveshaft works, or you could just drive in a tight circle in a parking lot and see if you get resistance.  If you do the front wheels are driving.
