Feeler... entertain me. PLEASE
  • 1736 Views
Offline yellow2000S/R
  • 152
« on: April 19, 2011, 02:25:08 AM »
HOW MUCH WOULD YOU PAY? If I get a high enough offer (probably out of the question), I'd consider selling.
Even if you don't have the $$$, how much do you think it's worth?
ASSUMING IT IS TOGETHER - Engine needs assembled after being picked up from machine shop. They're taking their merry time on completing all the work.
Item: 1996 Geo Tracker
Trans: 3spd auto
Miles: 112k miles on body/transmission, 0 on engine.
Basic new stuff:
Oil
Oil filter
Spark Plugs
Spark Plug Wires
#1 O2 sensor
#2 O2 sensor
2 cans Carb cleaner
PCV Valve
Full upper gasket kit
EGR vacuum control solenoid (x2)
Mods:
Looks:
Low Range Offroad 2" spring/strut spacer kit
Low Range Offroad 2" body lift
Crown Vic Rear Shocks
5.125 gears
Cragar V-5 15x7
30x9.5 BFG A/T
Modified front LCA to shift wheel out 5/8" to fix camber from lifting and forward for better firewall clearance and added caster.
Custom 3/16" front bumper made by me
Warn 5000lb winch
Performance:
Custom 2" SS mandrel bent exhaust (till turbo goes on)
Vacuum Block
SS oil feed/return lines for turbo
CXRacing front mount
3 angle valve job, 1 valve replaced
Head milled .015"
PnP
Head tanked/cleaned
Ported stock intake mani
Block decked
Block inspected
ARP head studs
ARP rod bolts
Main caps decked then line honed
New freeze plugs
Cylinders bored/honed for 75.5mm pistons
75.5mm YCP Vitara Pistons
D16z6 crankshaft (mains machined down to fit G16 block, flange holes plugged and drilled/tapped for Tracker flexplate, snout machined down nearly 1/2", keyway recut, machined down for oil pump to fit, machined for thrust bearing relocation)
Nitride treatment for the crank (soon, $170)
FJT D16 custom length rods
New oil pump
OEM size ACT Race bearings for the rods
Clevite thrust bearings
Sealed Power main bearings
Mazda e-bay cheapo turbo mani (will probably trash and make my own)
TB25 off a Saab, rebuilt (probably wont last LOL)
Ebay 'type-s' BOV. (best fake one according to the Honda guys haha)
Full gasket set
Waterpump
Gates Timing set
« Last Edit: April 19, 2011, 03:27:32 AM by yellow2000S/R »
Offline Jluck
  • 1389
  • 40
Re: Feeler... entertain me. PLEASE
« Reply #1 on: April 19, 2011, 03:09:54 AM »
1500-3000 IMO. You know how it is with incomplete projects. Just get it finished! It will be a sweet lil ride!
  • 152
« Reply #2 on: April 19, 2011, 03:26:31 AM »
LOL, thats under book value... this is assuming it's completed.
« Last Edit: April 19, 2011, 03:28:02 AM by yellow2000S/R »
Offline locjaw
  • 2045
  • 22
« Reply #3 on: April 19, 2011, 07:50:00 AM »
you really should know by now that it's hard to get your money back from mods. that being said, in a running driving condition im gonna say you'd prolly get $3500 maybe a little more depending on your marketplace. With it uncompleted, ill have to go with Jluck on his estimate of $1500 tops.
people should realize that only about 5 of every hundred people looking at a used car for sale care about performance(most care about mileage). if your gonna dump a shitload of $$ into motor work, you really better off planing to keep it first.
OH,I FORGOT...................................*dances around like a boob in a clown costume* ...........entertained yet???
« Last Edit: April 19, 2011, 07:58:08 AM by locjaw »
« Reply #4 on: April 19, 2011, 09:37:47 AM »
With it that clean and in good running condition, you could get around 4K for it on the east coast. But it would take a while to find someone that wanted what you have built. For a reasonable quick sale I would say $3500 tops.
« Reply #5 on: April 19, 2011, 04:32:33 PM »
What happened? That was going to be one sweet turbo rig.
  • 152
« Reply #6 on: April 20, 2011, 01:33:38 AM »
Nothing happened, just impatient with the machine shop. I'm off Thursday and Friday so I'll swing down and talk in person to figure out why there is such a delay and never any updates.
