hagen mod how much work?
  • 1899 Views
Offline beagle..t
  • 1239
  • 16
« on: April 16, 2011, 03:49:35 PM »
ok looked over the forum and was just wondering if someone makes them or do i have to make them myself.Also what else is envolved with this mod. another question i know that is mod pushes the front tires forward,but what about the rear axle could you not just lenghten the bars and add longer coils too accomidate  or would you have to move the rear coil buckets back too or is there a way to move the rear back that i did see in DIY
Re: hagen mod how much work?
« Reply #1 on: April 17, 2011, 05:22:41 AM »
Your going to have to do some cutting and welding to get it done. Maybe post in the wanted section for someone to make the parts you need, but you'll still need to cut and weld and drill some. The rear axle overotation requyires a offset upper link spacer to accomodate moving the axle around.
