Has anyone ever gone the OTHER way?
  • 24 Replies
  • 5233 Views
Offline 144man
  • 85
« on: April 13, 2011, 03:06:37 PM »
I know it's sacreligious, but has anyone ever converted a Sammy to full-time 2WD?  I'm thinking lose the front axle and t-case with all the associated weight and rolling resistance.  And with a stock 1.3, you'ld have a pretty economical daily driver, with the option to take the top off when the weather's nice.  All I would need is a beam front axle, maybe off a mail jeep, and maybe even a higher rear end for better milage.
Don't fret.  I have no such plans for my new-to-me bone stock '87 Sammy with only 61K on the clock.
I'm just thinking.
Re: Has anyone ever gone the OTHER way?
« Reply #1 on: April 13, 2011, 03:23:13 PM »
WHY convert it, when you can simply trade/sell it for a 2wd model? LESS work, and they allready exist.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #2 on: April 13, 2011, 05:28:06 PM »
I agree with T-Rex.... why go through that exercise to build something that will be worth less in value? Just my $.02.....
Online ebewley
  • 6554
  • 64
« Reply #3 on: April 13, 2011, 08:27:54 PM »
I'm just thinking.
Do you know they made 2wd model Samurai? It has a solid tube axle up front with no diff and a 'dummy' t-case with no front output... So, you could collect those pieces and bolt your 2wd together. I'm not sure you'd get better mileage as it's the aero package that's a problem with the Samurai, not the weight.
Good luck with what ever you decide.
« Reply #4 on: April 13, 2011, 10:28:17 PM »
LOL Ya, the aerodynamics of a Toaster   :laugh:
Offline Jluck
  • 1389
  • 40
« Reply #5 on: April 13, 2011, 10:29:56 PM »
I would bet the MPG gains would be little to none. I think I would just buy a car. (swift maybe)? ;)
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #6 on: April 14, 2011, 05:18:20 AM »
take your front d/s off...
Offline Jonny Rash
  • 1093
  • 20
  • Too many Samurais, too little time
« Reply #7 on: April 14, 2011, 06:07:43 AM »
Actually, I would like to build something like this from my one of my many parts Samurais.  Not for economics, but for a cool street cruiser-a safer motorcycle.
Last year I picked up a 2wd Samurai beam axle.  It is actually offset to lower the front end about 1/2".  I was thinking of lowering the Samurai even more by "frenching" in the spring mounts though.
For the engine and transmission, I would use a 1.6 and 1.6 manual tranny.  I would also convert the rear end to a trackick rear end so that the pumkin is centered.  Might even swap over the trackick rear coil suspension over too.  I've also considered swapping in a RX7 Rotary, but it really doesn't make that much power (the carbed versions) over the 1.6 Suzuki engine which is bolt-in.
Of course, I would ditch the doors, targa bar etc, and might even go without a windshield (front cage though).  It would be kind of like a lowered VW Thing or WWII era Kubelwagon.  I would paint it gray or dark green and put a big red dot on the hood-a Suzuki Zero!  Of course, I would drive it around with a leather flight cap, googles, and jacket.   :laugh:
« Last Edit: April 14, 2011, 06:13:32 AM by Jonny Rash »
25+ years of Samurai ownership!
Offline Jluck
  • 1389
  • 40
« Reply #8 on: April 14, 2011, 08:17:28 AM »
this would be a good place for a vw diesel.    40+ mpg maybe?
Online ebewley
  • 6554
  • 64
« Reply #9 on: April 14, 2011, 09:38:53 AM »
There you go sucking all the fun out of a nice ride.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #10 on: April 14, 2011, 10:24:54 AM »
In that case why not just swap the diesel? I thought they were capable of that kinda mileage in a stock samurai without cnberting to 2wd or any weight-loss
Online ebewley
  • 6554
  • 64
« Reply #11 on: April 14, 2011, 11:15:56 AM »
Yeah, but the driving experience is boooring... I "think" one of the goals here is to have a fun summer time kick around.
Offline Jonny Rash
  • 1093
  • 20
« Reply #12 on: April 14, 2011, 11:21:21 AM »
Yes, I'm with Eric.  I would like it to be quick with 0-60 under 10 secs.  That's probably doable with the 1600 8-valve and will be easily accomplished with the 16 valve.   8)  It will still get 25+mpg too, especially if the rig weighs less than 2000lbs.
« Last Edit: April 14, 2011, 11:22:58 AM by Jonny Rash »
« Reply #13 on: April 14, 2011, 06:40:34 PM »
Sad, ain't it, when you consider 0-60 in under 10 seconds to be quick.  ::)  If you want fun and still keep it Suzi powered, go with a 1.8 or 2.0 swap. Unless you are a glutton for punishment, that is ( Brdhntr and friends ) then go with a 2.7 V6 swap.
« Reply #14 on: April 14, 2011, 11:09:41 PM »
A 2.7 in a 2wd street sammy would be pretty damn cool. Hmmmm, maybe a rat rod style lj with a 2.7 kind of like this...
