monster vitara
  • 22 Replies
  • 5816 Views
Re: monster vitara
« Reply #15 on: April 19, 2011, 09:34:23 AM »
Mainly springs and shocks to get the ride and ride height we needed to clear the 37's. Plus, the fenders were trimmed and molded to help with clearance issues.
Offline djlantis57
  • 871
  • Take your chrome home
Re: monster vitara
« Reply #16 on: April 19, 2011, 10:54:44 AM »
djlantis, can you please explain me zukipilots rig ???
Zukipilot best explains Zukipilot's rig ;)
Offline Drew 4.0
  • 79
    • FireCrafter.com
Re: monster vitara
« Reply #17 on: April 19, 2011, 03:03:18 PM »
Thought I'd add my .02, I have a 4 door sidekick and ran the trail slayer kit with a stock 16v on 35's for over a year as my daily driver.  It was no fire ball but it did OK on the street and awesome off the street.  I was running 5.71 gears in Toyota axles with ARB's front and rear.  I've now upgraded my drive train with a 4.0 Toyota V6, I choose this engine because of its light weight, all aluminum block and heads, it's after market support of turbos, superchargers etc. and the availability of adapters to mate it up to Toyota transfer cases, doubled in my case.  None if these mods are cheep but if you do them in steps you can maintain a drivable working rig as you do your upgrades.  Depending on your fab skills a V8 would be pretty cool and there are some GM V8's that are all aluminum and probably wouldn't weigh much more than a V6, I think that the Trail blazer had a small all aluminum V8 that i considered.  I think that you will find that fuel injection is the only way to go, it will make your swap a bit harder dealing with the electronics but it will run right at any angle, no flooding issues, and much better fuel economy. The only other way around carbs is going with natural gas which is also an option but will make it a bit harder to fuel up and generally the gas cylinders end up inside your rig taking up precious space.  I think that what ever you do your going to have a really hard time staying in your budget!!  If you do go with the Toyota axles there are always the 30 spline Bobby Long axles that are rated for 1,200 HP I think.   Some of the parts to make your rig stronger can be added as you break things and don't need to be done right away.  Good luck and keep us posted!!
Offline Jluck
  • 1389
  • 40
Re: monster vitara
« Reply #18 on: April 19, 2011, 03:17:52 PM »
Whew.... I think that was more like .04 or .06 cents :P! Good info there!
Re: monster vitara
« Reply #19 on: April 28, 2011, 12:15:09 PM »
thanks for reply... what you thinking about the rover engine guys ??? and other think. i will probaby stick with 1.6 engine because i couldnt find gm v8 aluminuum engine.. (and i dont know if v8 can fit into the vitara. i seen loads of v6 but not v8)
and trying to find a holley 4 barrel or a weber twin carb to fit my vitara)
hope you know the answer.. specially for double twin weber carb
Re: monster vitara
« Reply #20 on: April 28, 2011, 05:32:54 PM »
I just ran Moab with a guy running a 90 Tracker 1.6 8v on 33"s, 4 door springs, locked both ends, very trimmed fenders, and his rig cleaned up Poison Spyder, Golden Spike, and Gold Rim.  He had been running the same rig for 3 years, and knew how to make it work.  The trick is knowing what YOU need.  5G will build a rig that should go anywhere, but just buying kits and big tires will eat it up Quickly.  Think out your mod.'s and make them for a purpose you need, then you might get your build done under 5G.
Re: monster vitara
« Reply #21 on: April 28, 2011, 06:33:22 PM »
yeah but 1600cc 8 valve is not enough for competition. at least i need to find a way to make it 2 twin carb or 1 4b barrel... i think im just tjinking too much extreme... :S
Re: monster vitara
« Reply #22 on: May 06, 2011, 01:19:01 AM »
i am looking forward your suggestions guys ;)
