Thanks. Yes im havin the whole thing looked at , ive decided on some other things since i made that post. Im havin the whole he re-built from the bottom up. Im takin the block in to the machine shop , i want him to measure out the bore of all 4 cylinders. Im hoping they come back good , if they do im ordering standard flattop pistons. He will also look at the rod bearings and main bearings ,hopefully they come back good , if not ill replace them. that should give me basically a rebuilt engine. Does anyone know how much extra hp flattop pistons give you over oem? I know they have like 68hp stock, after i know my engine is good and new though ill save some money and im going to buy the euro style manual choke weber carb,JDM style intake,Pacesetter header which i have already and a 2 .25 inch exhaust with a straight through cat which is already on to a straight through but quite flowmaster muffler, i used a univ highflow cat. How much hp will that setup net? im not to concerned i mean its a sammy im more into a solid running sammy , but hp is nice to have. Im thinkin New engine,Weber carb,JDM style intake,Header,High flw cat,exhaust,flattop pistons , im thinking about 85-90 crank hp. Let me know your opion. im going off the carb and intake would bring it to 75, header about 80, the highflow cat,exhaust and pistons , 85-90hp. I was going to use the HD carb setup , i just dont want to spend anywhere from 340-400 on a carbsetup.
