questions about new rig
  • 12 Replies
  • 2690 Views
Offline obradleyo
  • 45
« on: March 23, 2011, 11:55:35 AM »
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" GT radial mudders,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca IMG]http://i388.photobucket.com/albums/oo327/obradleyo/rock.jpg[/IMG]
Re: questions about new rig
« Reply #1 on: March 23, 2011, 12:20:05 PM »
The only way to get a high range drop is the undertaker or a Samurai T-Case.  Are you keeping the stock 4cyl or looking to drop in a V6?
Offline obradleyo
  • 45
« Reply #2 on: March 23, 2011, 02:30:08 PM »
keeping the stock 4. will the sami t-case hole up 38" tires?
Offline lepcur
  • 19
« Reply #3 on: March 23, 2011, 06:34:54 PM »
I think it would if you buy or make a t-case bucket for it.
« Reply #4 on: March 23, 2011, 06:48:30 PM »
No way you are going to pull 35 to 38 inch tires on 4.10 diff gears with
out an undertaker or a Samurai t-case with 6:1 gears in it.
Offline obradleyo
  • 45
« Reply #5 on: March 24, 2011, 10:26:32 AM »
I plan on building one im vary handy with a welder and a angle grinder.
This is why im posting here you guys are the experts on this stuff. im actuall only going to run 35 or 36's. would the 4.10 be ok
I also will be upgrading the t-case gears.
 so the 6:1 gears will turn the 36's good on the street with  the 4.10 or should i go 4.56 or 5.29?
one question tho could i use the 4 :1 or the 4.9:1 t case gears and still turn he 36s on the street?
Offline Jluck
  • 1389
  • 40
« Reply #6 on: March 24, 2011, 11:41:06 AM »
I'm confused here... are you planning a Ifs abortion or toy solid axles? either way 5.29's are about as high as you would want to go. you would probably need even lower gears. (numerically higher)
Offline obradleyo
  • 45
« Reply #7 on: March 24, 2011, 12:08:22 PM »
switching to toyota ifs  and using a sami t-case as stated up top
Offline jagular7
  • 1026
  • Jagular7
« Reply #8 on: March 24, 2011, 12:51:27 PM »
The low side of a Tracker case in only 1.8 or so. So keep that in low and run whatever tcase behind it. This will put the 4.10 feel like 7.38s. So either go bigger in tires or higher in diff gear ratio.
What is the tallest Toyota gear ratio? Anything in the high 2's?
Lenexa, KS
Offline obradleyo
  • 45
« Reply #9 on: March 24, 2011, 01:42:33 PM »
can you even do a kicker doubler anymore? I called OTT and they said not making anymore
« Reply #10 on: March 24, 2011, 02:16:10 PM »
With the XL7 automatic you should be able to change your output shaft over to a Toyota style and bolt up a transfer case from a Tacoma, not sure about the Suzuki 4 speed.  But it is a standard ASIAN transmission so possibly?
The only Toyota axle gearing I can find is 4.10, 4.88 and 5.29 as after-market.
« Reply #11 on: March 24, 2011, 08:43:47 PM »
I built a Samurai with 5.38s and a 4:1 t-case set with 35" tires and it was
way underpowered in low range but that was behind a 1.3 engine too.
I think you will want the 6:1 t-case set and 5.29 in the diffs to turn that
tall of a tire on the street.
I don't think there is any way you could run the Sidekick case in low range
and then run that through a samurai case and get any sort of highway speed
My sidekick stock in low range would go about 55 at 5000 RPM on 235 tires,
taller tires and gears might help, but I don't think you want to swap in 3.73
samurai gears to get any sort of speed for highway use, but run the #s thru
a gear and tire calculator to figure your speeds before you build
Offline obradleyo
  • 45
« Reply #12 on: March 25, 2011, 10:13:25 AM »
thanks a bunch wild. that was the info i needed...
So here is the plan 2wd sidekick or tracker 2 or 4 door dont care needs to be 16v tho i want the extra HP. sammy Tcase 6.5:1.  start with the 34" and 4.10 and up grade later. Use the whole toyota IFS so I only need to make new A-arms. Will probley use t_100 CV shaft's. im thinking the end amount of lift in the suspension wil be between 8 and 14 inches.  I will lift the front and then lift the rear to mach....I know there are a lot more odds and ends like brakes , drivelines and things like that but i will leave all that for the build diary....
I found a great deal on a toyota frame and running gear right now it has 34"s and 4.10 gears with a welded rear. i cant get it for a few weeks tho im going on vacation on my days off. its been on craigslist for like 3 months already and has not sold so hopefully its still there.
http://www.lowrangeoffroad.com/suzuki/samurai/transfer-case/suzuki-samurai-6-5-1-fully-rebuilt-transfer-cases.html
