Hit your injectors with 12v, if they click then they are working. Do NOT do this with an 8 valve, as you will break the injector. As for the leaking on #1, your o-ring is most likely damaged or slipped off. Autozone has cheap injectors available, or give Hawk Suzuki a call and they can send you some used ones.
