winches
  • 12 Replies
  • 3016 Views
Offline wolf530
  • 6
winches
« on: March 05, 2011, 07:51:22 PM »
Is the smittybilt xrc hd winch reliable  and how dose the air work
Re: winches
« Reply #1 on: March 06, 2011, 01:53:47 AM »
For the price, sure.  I have also used the Harbor Freight winches without issues.  The cheaper winches may be slower but they will get the job done.
But if you want a quick winch that won't break down you should spend the extra money and get a WARN.  They are at the top of the list for a reason.
As for the on-board air bit, it's just a standard compressor slapped on top of a winch.  My guess is it didn't work very well as I found the following when I went to their website for statistics on the air pump:
Due to unforeseen circumstances the XRC10 HD winch has been discontinued at this time.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: winches
« Reply #2 on: March 06, 2011, 02:30:23 AM »
FWIW....
I have a 9K Chicago Electric that is sold by Harbour Freight. They are made by Multi-Mile, if something does go bad you can get parts for it through Multi-Mile. I had to buy a solenoid becacause some AzzHat decided instead of buying their replacement they would just steal mine. I called Multi-Mile told them what I needed and that I wanted to "upgrade" to their parts and they fixed me right up.
Other than the theft issue I haven't had any troubles with mine.  8)
« Last Edit: March 07, 2011, 01:32:02 PM by tuxblacray »
Offline lv2fsh
  • 312
  • 19
Re: winches
« Reply #3 on: March 06, 2011, 06:12:29 AM »
This what I have. Slow but works just great. Customer service from the guy was excellent. It says 5000# but is actually 6000# and the exact same as their 6000#. Had it for a couple of years now and have used it a few times.
http://cgi.ebay.com/VORTEX-5000-LB-Pound-Recovery-Winch-Bonus-Package-JEEP-/170544676900?pt=LH_DefaultDomain_0&hash=item27b5414024
Re: winches
« Reply #4 on: March 06, 2011, 08:03:21 AM »
Anyone use the Chicago 3000lb 12 volt camouflage remote controlled winch from Harbor Freight? I can buy for 1/2 price ($50).
LOT No. 95912.
Re: winches
« Reply #5 on: March 06, 2011, 06:55:20 PM »
The general rule of thumb is 1.5x the weight of the vehicle you want to pull.  So a 3000lb winch will help tug you out of a ditch, but any more then that you will have to double up your cable which means it will pull twice as slow.  For a Sammy most people go with 6000lb winches, which are usually close to the same cost as the 8k.
lv2fsh:  That's pretty cool.  We have used the remote controller attached to that winch on BRD_HNTR's Tracker, it works great and allows you to tuck the control box under the hood.  Roadless Gear has the controllers, along with a nice in-dash winch control unit I use in my SJ.
http://www.roadlessgear.com/page/RGL/CTGY/R
Offline lv2fsh
  • 312
  • 19
Re: winches
« Reply #6 on: March 06, 2011, 07:50:56 PM »
I just use the key fob remote inside and out. ;D
Offline Jluck
  • 1389
  • 40
Re: winches
« Reply #7 on: March 06, 2011, 08:01:27 PM »
also, most winch manufacturers use the same platform for the 6&8k winches so theres very little weight difference. I would go for the 8k if thats the case.
Offline lv2fsh
  • 312
  • 19
Re: winches
« Reply #8 on: March 06, 2011, 08:10:56 PM »
Usually the weight jumps dramatically when you go above 6000#. I the case of the one I have it was like 40 some lbs to 90 some. Price wasn't that dramatic but I didn't want the extra weight.
Re: winches
« Reply #9 on: March 07, 2011, 08:32:59 AM »
Our general rule of thumb for winches is 1.5 x GVRW.
And if anyone has any questions about any of our products, feel free to give me a shout.
- Andy
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Re: winches
« Reply #10 on: March 07, 2011, 08:36:05 AM »
Oops that's "GVWR" (gross vehicle weight rating)
Re: winches
« Reply #11 on: March 08, 2011, 02:01:47 PM »
- Andy
As lv2fsh pointed out, the weight difference can be a factor.  Annoying since a lot of places don't list the weight...  One way to save weight is to switch to the rope, but is it worth it on a DD where the winch will see maybe see the line pulled out once or twice a year?  How does the rope stand up to being ignored compared to the old school cable?
Re: winches
« Reply #12 on: March 10, 2011, 09:01:52 AM »
