93 Tin top tracker
  • 47 Replies
  • 17531 Views
Offline vw505
  • 133
Re: 93 Tin top tracker
« Reply #15 on: March 13, 2011, 10:18:15 AM »
Is there any thing i can do with the timing to give me a little more power down low?
« Reply #16 on: March 13, 2011, 04:17:36 PM »
Only if it isn't running right to begin with.  I run mine about 2 degree advanced over stock, but with plugs that were gapped to large I ran it a bit more.
Offline vw505
  • 133
« Reply #17 on: March 13, 2011, 05:29:22 PM »
do you think bumping up the timing would help with the high NOX i am getting ?
Offline vw505
  • 133
« Reply #18 on: March 17, 2011, 08:38:08 PM »
So i took the tracker to Fallon,Nv I am out here for the next month training. Today i went for a little drive out on the public land. All i can say is that i am realy surprised how well it did.
« Reply #19 on: March 17, 2011, 10:59:00 PM »
With good plugs and wires your timing should be set to spec.  But some of us have found that a lot of engines like 1-2 degree advancement over stock.  On my engine I would see a bit of a dead zone in power between 2-3k and a drop in mileage.  Right now I get 25mpg with 23lb's of air in the tires.
Offline vw505
  • 133
« Reply #20 on: March 25, 2011, 09:28:25 PM »
So i been rideing alot and this thing is awsome
Offline vw505
  • 133
« Reply #21 on: March 27, 2011, 09:58:54 AM »
I installed my Sky body lift but i cant get in 2w high? what can i do with the shift lever?
« Last Edit: March 27, 2011, 10:09:12 AM by vw505 »
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #22 on: March 27, 2011, 12:09:18 PM »
Did it come with a shaft extension? I thought that was required. If you have that and it still doesn't fit then I'd think it just needs to be bent a little
« Reply #23 on: March 30, 2011, 09:52:42 PM »
High NOX is from too fast of a burn, more advance will make
the NOX worse, so go to stock or even 1-2 retarded just for
smog check, then dial in 1-2 advance in your timing for driving
Offline vw505
  • 133
« Reply #24 on: April 03, 2011, 01:24:41 PM »
I am going to take this in for a new cat back now that i have my new manifold. I was thinking 2 1/4 with a good muffler that size sounds about standard.
« Reply #25 on: April 05, 2011, 08:44:20 AM »
2" is what most have gone to, unless you are turbocharged, then
it's what ever will fit, but you need some back pressure to run best,
or you might find you lose power and/or economy
Offline vw505
  • 133
« Reply #26 on: April 06, 2011, 07:32:09 PM »
2" sounds good to me.
Offline vw505
  • 133
« Reply #27 on: April 14, 2011, 08:26:36 PM »
Offline vw505
  • 133
« Reply #28 on: April 14, 2011, 08:27:35 PM »
« Reply #29 on: April 15, 2011, 10:16:31 AM »
Looks good.  Now you need bumpers.  :)
