TRACKER 89 transfercase to 95
  • 1200 Views
« on: March 02, 2011, 12:08:37 PM »
Just wondering if somone could spare some knowledge.
I searched and still haven't been able to confirm if a 89 tracker t case will work in a 95.
The 89 was 1.6 8v, 5 speed and the 95 is 1.6 16v , 5 speed.
I was told that the rear out spline may be different and was hoping someone could confirm it.
Thanks.
Offline smife
  • 179
Re: TRACKER 89 transfercase to 95
« Reply #1 on: March 02, 2011, 01:38:05 PM »
I believe the rear output spline is different. You would either need the driveshaft from the 89 or a t case from a 95 or newer Tracker
Offline Jluck
  • 1389
  • 40
« Reply #2 on: March 02, 2011, 03:18:18 PM »
I think your safe until 99 'ish before the output spline change.
« Reply #3 on: March 03, 2011, 07:53:06 PM »
The driveshaft spline changed in 96 to 16 spline.  89-95 tcases have a 26 spline tcase output shaft.
« Reply #4 on: March 04, 2011, 12:20:46 PM »
Ok cool so an 89 case should work on the 95 trans then.
Thanks everyone for the help!
