Need 4.62 3rd members
  • 12 Replies
  • 2137 Views
Offline BSulla
  • 6
« on: February 28, 2011, 04:47:22 PM »
I have a 98 3spd auto tracker with 30" tires  and would like to swap to 4.62 gears.
Offline inchaos10
  • 162
Re: Need 4.62 3rd members
« Reply #1 on: February 28, 2011, 07:25:44 PM »
Do you need complete thirds or will just the ring and pinion do?
« Reply #2 on: February 28, 2011, 07:53:44 PM »
I don't understand why you want 4.62s???
You need to go the other way with bigger tires, unless you are going
to do a back to stock conversion, and BTW you should have a 4 speed
auto trans unless I'm mistaken
Offline BSulla
  • 6
« Reply #3 on: March 01, 2011, 02:59:44 AM »
I need complete thirds,I don't know how to set up a ring and pinion.      I have 4.30's now and thought 4.62's woul get me back to stock drivability?
« Reply #4 on: March 01, 2011, 04:12:29 AM »
If your going to stay with that size tire I think a 4.62 is a good choice, IMO. Eventually you could probably go a tad bigger, say 31's.
« Reply #5 on: March 01, 2011, 06:52:56 AM »
If he has a 2 door, it will have the 3 speed auto and 4.30 gears.  So 4.62s would actually be better for bigger tires.
BSulla....a bolt in front 4.62 third is going to be hard to find, for yours.  Because you have the 26 spline sidegears in the front and the only third that will have a 4.62 third with 26 spline sidegears is going to be a 96-98 suzuki X90.  I do have a rear 4.62 third that will work for you, but I don't have any front 4.62 thirds that will have 26 spline sidegears.
I thought of a way to get you what you need....I'll send you a PM with some details.
Offline Jluck
  • 1389
  • 40
« Reply #6 on: March 01, 2011, 08:28:54 AM »
those 4.30's are kinda hard to find and sought after by guys doing the diesel swaps so you should be able to fetch good money for them.
FYI
« Reply #7 on: March 01, 2011, 08:53:53 AM »
Then I would say go to a 5.12, I thought he had 5.12 to start with, not
4.30s, the jump from 4.3 to 4.62 is not much and you will be disappointed
Offline Jluck
  • 1389
  • 40
« Reply #8 on: March 01, 2011, 09:38:06 AM »
I agree,'also 5.12's are readily available
4.3 to 4.6 would be a waste of time IMO
Offline BSulla
  • 6
« Reply #9 on: March 01, 2011, 03:23:05 PM »
At first I was looking for 5.12's but read some posts that I would be turning too many rpm's on the highway. My 30" tires are brand new so I will have them awhile but my next set will be 31's. So I guess I'm still confused on what ratio I need. What I do know is I need to buy some very soon as this thing is a turd on the freeway.
Offline Shadow
  • 174
« Reply #10 on: March 01, 2011, 06:17:46 PM »
FWIW My Grand Vitara 5spd came stock with 4.30's, I lifted it and put on 30" tires, I regeared it to 5.13's. The speedo is off on the highway but it takes off like it should have from stock, and off-road it is awesome considering that there are no 4:1 t-case gears available for it. Go with the 5.12's. If you are really set on the 4.62's I'll trade mine for your stock 4.30's four our hard top samurai.
« Reply #11 on: March 01, 2011, 10:10:40 PM »
Here, this might help you
http://wildcatent.freeyellow.com/zookmods/calc.htm
Enjoy
Offline BSulla
  • 6
« Reply #12 on: March 05, 2011, 04:40:20 PM »
Thanks for the calculator app. I'm going to go with 5.12's thanks for the advice guys.
