YJ leaf swap info needed..
  • 1694 Views
Offline Hyper
  • 35
  • Still learnin'
« on: February 24, 2011, 07:12:22 PM »
Ok fellas,
I've been trying to read up on swapping in the YJ springs in my Sami. After several search both here and on the web, I still don't feel like I have all the answers I need.
So far, everything keeps pointing me back to the JP Eater setup from Trail Tough. Is this the only setup to do this with, or are there other options I'm just not seeing.
Thanks for the help.
91' Tracker LSI
02' XL7
92' Samurai - sold.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: YJ leaf swap info needed..
« Reply #1 on: February 24, 2011, 08:27:38 PM »
  YJ swap can also be done with other vendors. Just off the top of my head I will name a few. Rocky Road Outfitters, Asian Auto Parts of Arizona has a shackle reversal, and Aftermarket 4x4 has a yj kit also.
Offline Hyper
  • 35
  • Still learnin'
« Reply #2 on: February 24, 2011, 10:12:58 PM »
Thanks flexmonger.
Typed up the post while at work... I actually did mean Rocky Road, not Trail Tough.
I appreciate the sites you mentioned, Aftermarket 4x4 seems to have the best pricing on the setup, so I'll probably go that route. I wasn't sure if anyone had been fabbing their own setups or not.
Hopefully I'll be able to get this rolling soon.. tired of bouncing so much!
91' Tracker LSI
02' XL7
92' Samurai - sold.
Offline erik the red
  • 174
    • Cascade Adventure Guides
« Reply #3 on: February 25, 2011, 03:41:24 PM »
I think one main difference between kits is that the Rocky Road JP Eater does not use a missing link setup, whereas most of the other pre-made kits do.
Something to keep in mind if you will be driving your rig on the road much.
1996 Geo Tracker
1987 Suzuki Samurai soft top
1987 Suzuki Samurai Tin Top
1972 Suzuki LJ20V
Offline Hyper
  • 35
  • Still learnin'
« Reply #4 on: February 25, 2011, 10:03:56 PM »
Ah! Thanks for pointing that out.
I had read another member on the forums here that mentioned how he had to tighten up the links in order to gain some road manners; I'll be sure to look for that before buying as this is my dd.
91' Tracker LSI
02' XL7
92' Samurai - sold.
