86 samurai
  • 16 Replies
  • 3811 Views
Offline Capt
  • 738
  • 28
Re: 86 samurai
« Reply #15 on: April 16, 2011, 08:17:54 AM »
FYI,
My experience has been that drive line noise's are "Gemlin's" that hide
in spots that you never think where the noise is coming from.
I had 3 sets of drive line noise in the past.
1) The rear axle outside (wheel) bearing was going, It sounded like the diff was going.
The next 2; I thought I had a tranny bearing giving up the ghost at 2 different times:
    1st) It was a u-joint on the short drive shaft between the Tranny & Trans Case
    2nd) I swapped in 4.9 gears in the Trans case and found that the rear output shaft bearing was "Getting Tired"
          After a complete rebuild (Including the new gears) "Problem All Gone"
Also in the past, I have had rigid mounted exhaust points cause some "At Speed" howls.
Good Luck,
CAPT
Offline hazmat
Re: 86 samurai
« Reply #16 on: April 16, 2011, 03:45:19 PM »
Thanks Capt for the info.  I'm starting with the RE and the TC and will follow the sound until hopefully I'll find it.  At 30 40 mph it roars and i can let off the gas or press in the clutch and it will stop.  Haven't had a chance to looked at it today because of Tornado warnings all day in my part of SC.
