Well... here we go. 1995 Sidekick JX with SAS
  • 15 Replies
  • 4237 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: February 23, 2011, 05:15:35 PM »
« Last Edit: March 11, 2011, 07:13:10 PM by hcgalvin »
Heather Galvin
Re: Well... here we go. 1995 Sidekick JX with SAS
« Reply #1 on: February 24, 2011, 09:19:09 AM »
Damn, I hate to hear you are getting rid of your ride.... BUT, that's one awesome deal for someone on the forum......
« Reply #2 on: February 24, 2011, 09:45:15 PM »
Hey heather, I have one more idea, do you have an oil pressure gauge?
I wonder if the same thing happened to your oil pump that caused me
to blow the turbo in Moab, low oil pressure from a stuck blow off valve.
Once the oil gets warm the pressure drops and causes a rod to get noisy
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: February 25, 2011, 04:41:36 AM »
Nah, I don't, just the stock idiot light. And it's developed this other lower knock after I shot the video. I think at this point the inconsistent tapping in the video is the intake (an injector probably), but now it's got something noisier... it's possible you're correct, though, since it only does it when warm, maybe it is the oil pump. Well, maybe that means it's an easier fix for someone who wants to buy this truck.
I'm going to let it sit on the market for a bit, if it doesn't sell, I'll probably go that route I suppose, but I'm going to give it a chance for now.
EDIT:
Well, Darin (I hope I spelled that right, it's been so long!  :P), I'm gonna go ahead and give this oil pressure gauge a shot this weekend, and see if that's what it is. An oil pressure gauge is a fairly cheap diagnostic tool. Thanks for the advice.
« Last Edit: February 25, 2011, 11:05:20 AM by hcgalvin »
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #4 on: March 02, 2011, 08:18:30 AM »
Bump... $3250 or reasonable offer.
I still have yet to install that oil pressure gauge, I bought one, but got carried away with family stuff over the weekend. I'll install it in the next couple of days.
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: March 04, 2011, 02:02:51 PM »
Forgot to mention that it comes with a towbar, could be easily hooked up and taken home. It tracks fine with it.
Heather Galvin
Offline jagular7
  • 1026
  • Jagular7
« Reply #6 on: March 06, 2011, 01:37:33 PM »
Have a friend that I showed this to today. He's got a Yukon Denali to sell and he'll be all over this.
We're here out in KC metro area.
Lenexa, KS
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: March 06, 2011, 06:25:40 PM »
That's cool... but the truck's in Boise, ID, not sure if you knew that?  ??? Sorry, I probably also should have posted that for those folks that can't see my profile.
For those folks looking for updates on the oil pressure gauge and results, I'm still working on it, I got it mostly set up, except I had to order an adapter. Our oil sender holes in the engine blocks take a 1/8" BSPT fitting, not a 1/8" NPT fitting which is what seems to come with most oil pressure gauge kits.  ::)
Heather Galvin
Offline Donald_R
  • 87
« Reply #8 on: March 07, 2011, 10:24:19 PM »
Heather,
Are you now done with rock crawling off-roading trips?
Don.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: March 09, 2011, 06:11:16 PM »
Ok, so... I got the gauge installed, and we're sitting at about 55-60psi when cold at idle, then after a drive to get some burgers, 20-22psi when hot. From what I've read, this appears normal?
Hmm...
Well, at least there's that.
FWIW, we're $3000 now or reasonable offer.
Heather Galvin
« Reply #10 on: March 09, 2011, 06:57:42 PM »
Sounds about right on oil pressure. Have you looked at your cam bearing for signs of any lateral movement? Could cause knocking sounds. But, it really sounds like your just ready to move on to something else.
« Reply #11 on: March 10, 2011, 01:19:03 PM »
Well then blame the noise on piston slap, these engines do that after the miles
are on them, it's not dangerous, just annoying
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #12 on: March 10, 2011, 01:38:38 PM »
Uhm... it picked up a different knock than what's in the video that I put up here a while back.  ::) I don't know if it was something I did when I was doing the valve lash, I don't quite see how, but knowing my luck...  :-X
I'll take video of it and put it up in a bit.
And please, guys, feel free to make an offer. Nate even said we could deliver probably up to ~300 miles.
Heather
Heather Galvin
« Reply #13 on: March 10, 2011, 03:22:49 PM »
PM Sent.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #14 on: March 10, 2011, 05:48:18 PM »
SOLD.
Thanks for all of your interest.
Heather Galvin
