lift suggestions
  • 11 Replies
  • 1560 Views
Offline brian7903
  • 16
lift suggestions
« on: February 15, 2011, 10:18:05 PM »
i have a 94 geo tracker 5 speed and would appreciate some suggestions on which lift to do i want it to be minimally priced i have 1 inch coil spacers in it now and have 31" tires on it that i just cant turn all the way. was wondering if any knew of and cheap priced but still relatively good and not a complete pain to install as this is my daily driver should be like a day or two project thanks in advance
Brian
94 geo tracker standard transmission 1" coil spacers 31"x10.5xr15 tires
Offline jeff1997
  • 1228
  • 27
Re: lift suggestions
« Reply #1 on: February 16, 2011, 05:54:52 AM »
You could put larger coil and strut spacers in. That will get you 2" of lift. You could also use lift springs for another 2" and smaller spacers to stay about 3" total.
3" Masterkit1 body lift
Custom strut spacers
Offline brian7903
  • 16
« Reply #2 on: February 16, 2011, 08:53:49 AM »
any idea which ones to put in or anything like that?
Offline rascott
  • 669
  • 15
« Reply #3 on: February 16, 2011, 10:35:44 AM »
i used jeff's spacers(jeff1997), but still needed to lift the body slightly and modify the front wells some to make my 31's fit.
Offline jeff1997
  • 1228
  • 27
« Reply #4 on: February 16, 2011, 11:01:42 AM »
Of course I recommend using MY coil and strut spacers. They are the BEST!!!  :laugh:
« Reply #5 on: February 17, 2011, 10:01:14 PM »
When you say that you can't turn all the way, do you mean that your tires are hitting the rear of the fender wells or the frame?
Offline brian7903
  • 16
« Reply #6 on: February 18, 2011, 09:02:25 AM »
im pretty sure it is the wells it is hitting
Offline brian7903
  • 16
« Reply #7 on: February 18, 2011, 09:03:49 AM »
how do you spacers run price wise and how easy are they to install?
Offline jeff1997
  • 1228
  • 27
« Reply #8 on: February 18, 2011, 12:17:02 PM »
A set shipped to you for a 94 would be $140 in US or $155 to Canada. That includes 2-1.5" coil 2-1.5" strut and 2-2" coil spacers. The 1.5" are up front and 2" in rear. You need to get longer shocks for the rear but that is it.
Offline brian7903
  • 16
« Reply #9 on: February 18, 2011, 08:11:10 PM »
i also looked for your ebay name but couldnt find it perhaps you could put a link or copy paste the website with one of your items listed on here. i have heard very good things on the forunms about your items!
Offline brian7903
  • 16
« Reply #10 on: February 18, 2011, 09:04:04 PM »
i modified the wheel wells quite a bit and im like barley off from having them fit...
Offline jeff1997
  • 1228
  • 27
