Diesel oil?
  • 1808 Views
Diesel oil?
« on: February 01, 2011, 10:54:31 PM »
Re: Diesel oil?
« Reply #1 on: February 02, 2011, 02:37:36 PM »
15w40 is pretty heavy for a samurai.  I'd stick with either a 5w or 10w oil.  Personally, I run 5w30 in mine (kansas city, mo area).
Offline truckpdlr
  • 23
Re: Diesel oil?
« Reply #2 on: February 02, 2011, 05:37:37 PM »
My owners manual for my 87 Sami says to use 15-40. I'm located in AZ and thats what I'm using.
Bone stock 87 Sammi
Offline Jluck
  • 1389
  • 40
Re: Diesel oil?
« Reply #3 on: February 02, 2011, 06:20:07 PM »
As you know the Delo is good oil, use it and add a bottle of marvels mystery oil to it to thin it a bit and help lubricate and clean you engine too. Sounds like a win win.
Re: Diesel oil?
« Reply #4 on: February 02, 2011, 07:54:34 PM »
15w-40 is fine in warm weather, it's a little heavy in the winter, that's when I
switch over to 5w-30, remember the first # is the real weight of the oil, the
second # is the simulated weight when the polymer additives lengthen out
and try to make the oil act thicker, even tho it isn't.
The best oil for lubrication is 30W not multi-grade, but most people these
days don't have the patience to wait for the engine to warm before driving,
so we use multi-grade oils so our engines survive to cold drive.
In the summer I use 20w-50 because the 5w-30 would cause the light to
come on at idle when it gets to 110* outside
Re: Diesel oil?
« Reply #5 on: February 03, 2011, 05:29:59 PM »
Re: Diesel oil?
« Reply #6 on: February 03, 2011, 09:37:06 PM »
40 w is too heavy for your samurai. Go for 10w its by the recommendation. Check out for online documentation or the dealer for a good idea. Run your Samurai with this grade of oil in cold regions will ruin the engine..
