sloppy steering
  • 1267 Views
sloppy steering
« on: January 26, 2011, 09:33:44 PM »
Hey guys, just bought an 86 and its all stock but the 29" bgg all terrians. My question is what is causing the sloppy steering in it? there is about 4" of play in either direction in the steering wheel...doesnt feel very safe. Could it be the steering box,tie rod ends, etc....?
Thanks
Offline mike5721947
  • 545
Re: sloppy steering
« Reply #1 on: January 26, 2011, 10:11:42 PM »
get a friend to saw the wheel back and forth while you look at the steering, you should see where its sloppy. also try lifting the front axle off the ground and grabbing the front wheels and shifting them, there should be NO slop between the front tires.
31" kumhos 3inchs of lift.
Offline jawman
  • 406
  • 1234
Re: sloppy steering
« Reply #2 on: January 26, 2011, 11:48:37 PM »
it could be worn joints,worn box, etc. I have a trackick that had bad wheel bearings, and you could not drive it straight at all.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: sloppy steering
« Reply #3 on: January 27, 2011, 11:51:39 PM »
I would check your rod ends, as jawman said.  It's pretty dangerous to be driving with that much slop.
