Can a 4dr with OME front struts have a front alignment in specs?
  • 9 Replies
  • 1889 Views
Offline RJkick
  • 631
Just thought I would ask those who know as 2 shops told me they could get close but it would still be out.  I have camber bolts but I guess the longer strut does too much to the camber?
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
  • 4318
  • 167
Re: Can a 4dr with OME front struts have a front alignment in specs?
« Reply #1 on: January 18, 2011, 05:26:26 PM »
Replacing the strut in and of itself should not change the alignment any - now - if you change the spring and the strut, that will probably change the ride height, which will affect both the camber and toe.
It's not the length of the strut that causes the change in alignment, it's the difference in ride height - if you added a few hundred pounds of winch and bumper so the front end sits lower, the camber will be out (negative), but if you exactly compensate for this decrease in ride height, by adding a spacer or uprated spring, you would bring the camber back to the factory position, but - on the other hand - if your spacer or spring lifted the front end, the camber would then go positive.
By the way - my ARB catalogue says OME struts can be used with the standard springs
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline RJkick
  • 631
« Reply #2 on: January 19, 2011, 10:40:08 AM »
Sorry about this but I didn't include all the pieces so it would be near impossible to answer - but you did an excellent job and I understand now
OME longer than stock struts #962 I think
OME 962 springs
OME N103 struts
3/4 inch spacer
about 4.5 inches of lift with a pre-runner bumper so not a lot of weight
Thoughts
« Reply #3 on: January 19, 2011, 10:43:29 AM »
Yea.. that sounds right... Plus they say that about most modified vehicles for liability issues... some shops wont even touch am off road vehicle that's been lifted....
  • 4318
  • 167
« Reply #4 on: January 19, 2011, 01:08:37 PM »
With that much lift - it might be difficult to get the camber back where it should be - but I'm just guessing.
« Reply #5 on: January 20, 2011, 04:43:49 AM »
Thats 3" more lift than the OME struts were designed for, I don't think that you will get that in spec just with the bolts.
Offline RJkick
  • 631
« Reply #6 on: January 20, 2011, 09:41:37 AM »
Such is life I suppose
I guess I can rotate the tires more to try to have them wear more evenly
Thanks
« Reply #7 on: January 20, 2011, 12:32:15 PM »
They should be able to grind out the holes in order to get the alignment back to stock.  That is what my local shop did instead of using the camber bolts.
« Reply #8 on: January 20, 2011, 04:21:43 PM »
I'm also using OME struts with all kinds of bastardized mods to get about 4" of suspension lift, and my shop was able to align mine just fine.  I was able to get the camber to 0 degrees just using camber bolts, but like I said mine is a real mish mash of parts.
Offline RJkick
  • 631
« Reply #9 on: January 24, 2011, 10:58:16 AM »
Gives me hope
I'll talk to my 4X4 shop to see what we can do
Otherwise I may have to do it
Thanks
