I hope you can help. This has stumped two mechanics so far.
This is the first winter with my '99 2.0 Tracker (4 door auto w/ 79k). On the first snow packed roads this winter, I put it in 4wd, light came on and over 35 mph the truck growls like an angry cat and it didn't appear that the 4wd was engaged. I put it into 2wd with the hubs still locked and the growling sounds were reduced but the truck swayed from left to right with a mind of its own. I unlocked the hubs and the truck was happy again.
I had the front differential replaced-had some metal flake, checked the transfer case oil and did an alignment. Next snowstorm, the growling came right back so I went right back to rwd and have driven on the roads that way since. When I go to my boyfriend's house which can only be accessed in the winter with 4wd, the 4wd will work there every time and without the growling (I'm going 5pm uphill).
This is my 3rd Tracker ('90 & '95 both with auto-locking hubs that were claimed by rust or they would still be here) and I have never had this problem. Does anyone know what it might be?
(One other unsolved issue: When under moderate to heavy acceleration in rwd, you can feel a 'thump' in the rear of the vehicle. This will only occur when going from 1st to 2nd gear. The entire rear end has been replace, exhaust tightened, transmission mount bolts are tight, spare tire bolts and mount checked/tightened, u-joints replaced, mechanics stumped again. Possibly related?)
Any suggestions are appreciated. Thanks!
