sidekick pinout sheet? anybody have one??
  • 2121 Views
Offline Jluck
  • 1389
  • 40
« on: January 12, 2011, 10:16:32 AM »
I'm looking for a pin out sheet for ecm (or whatever 'ya prefer to call the engine management computer) Im working with a 92 jx 16v 4door kick and need the pin sheet for the comp. thanks
Re: sidekick pinout sheet? anybody have one??
« Reply #1 on: January 12, 2011, 12:20:16 PM »
I have a 93 FSM (at home), and it does not have a direct pin out.  I went through the electrical pages to get what I needed, as it is organized by controls ie charging, lights, brakes etc.
You should only be needing a few of the pins for power, memory power, rpm, oil pressue (light), temp guage, starter signal, ignition, GROUND.  Off top of my head, I will check my wiring lists as to where I routed those to off the new ECM, this evening.
If you need a VSS signal for the ECM, you can get an adapter from the speedo cable to VSS, but the OBD I  VSS signal from some speedo's are not compatible with OBD II VSS signals (which is probably what your Audi is).
« Reply #3 on: January 12, 2011, 02:54:59 PM »
Rhinoman to the rescue! ;D
Offline Jluck
  • 1389
  • 40
« Reply #4 on: January 12, 2011, 03:15:10 PM »
thank you Rhinoman!!!  TP up!
« Reply #5 on: January 12, 2011, 04:46:33 PM »
That is much easier than the way I did it.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #6 on: January 12, 2011, 06:16:33 PM »
Too late to mention this I guess, but here is a detailed TracKick wiring document by Warbird created for building a Samurai 1.6 wiring harness:
http://www.acksfaq.com/16wiringharness.htm
It has lots of detailed info about all the electrical plugs - including the ECM!
I hope that this helps!
Ack
Offline Jluck
  • 1389
  • 40
« Reply #7 on: January 13, 2011, 11:24:07 PM »
wow thanks ack! lots of great info.
« Reply #8 on: January 14, 2011, 07:49:22 AM »
VERY GOOD information.  I have bookmarked it for next time.  Thanks for all the information you have gathered and shared.
