Looking for carb recommendations (1st post)
  • 2384 Views
« on: January 11, 2011, 08:20:20 PM »
A new Samurai owner here (1988) looking for your input. While I have not had time to verify it yet it seems the choke takes a long time to kick off in cold weather all the while it is running rough and extremely rich. This is the stock carburetor and does anyone have suggestions or experience in how to remedy this?
PS: This is a great website!
Offline z3ro
  • 339
Re: Looking for carb recommendations (1st post)
« Reply #1 on: January 11, 2011, 08:35:00 PM »
Is your pre-heater hose hooked up?  This will help somewhat.
« Reply #2 on: January 12, 2011, 07:28:25 PM »
Yes, it connected and in reasonably good shape for it age.
Offline airmanwilliams
  • 913
« Reply #3 on: January 13, 2011, 07:25:47 AM »
im saving up for a myside kit. you should just go with a myside as well, ive heard nothing but great things from them.
1993 4door Suzuki Sidekick JX
Offline z3ro
  • 339
« Reply #4 on: January 13, 2011, 06:49:58 PM »
That's like saying "Do an engine swap to fix your oil leak problem."
Mine doesn't run rough in the cold weather, although it does run rich while warming up.  Rough idle points to other problems, not just the choke.  Have you checked everything else out?  Strong ignition?  Vacuum leaks?  Exhaust leaks? Valves adjusted properly?  Dirty carb?  etc?
These items can all contribute to rough idle.  If it stops when it gets warmed up, thats a clue.
« Reply #5 on: January 15, 2011, 04:51:51 PM »
Today I changed the spark plugs. Found one vacuum hose broken and replaced it. Cleaned the PVC valve. Changed the fuel filter. It was dirty. Lube the linkages. The choke does not kick open after warm up. I found a piece of binding wire that the previous owner had on it to hold the choke open. With it wired open the engine ran well. Further diagnostics for tomorrow.
